Now I'm wondering if I have mine installed backwards or if I got lucky and won the coin toss. Can't wait to compare mine to the above installs. I did try it both ways and it seemed to fit either direction.
They fit and all the holes lined up both ways? I had trouble getting the rear tucked in on my first liner and got worried that it was backwards. For a second I tried to pull it out but it wasnt coming easy so I stopped. Turned out to be the right direction. It's pretty clear what way they go after looking at them and the instructions.
Thanks to 67L48. I ordered from Advance Auto Parts for $88.27 shipped for my 2019. Used coupon code RMN25. Will post pics once received and installed. Thanks again 67L48!!
You can get the Penda brand from Advance Auto Parts for $110 and use a 25% off coupon to $82.50. Again, I’m pretty sure Penda makes the liners for Ford.
Thanks for the heads up. I purchased my liners for $89.31 and free shipping, they added state sales taxes. Thanks again.
Ordered 3 days ago. Put on today, thank you for the poster who linked to the Penda liners. Literally took 20 minutes. Look at each one when you open the box, you'll see they are stamped with "LH/RH". Looks great and fits perfect!
When installing I could never figure out which way to install. The molding in slightly different if installed on the left or right side. Looking at the picture above it looks like dryden131 installed his opposite of 67L48. Does anyone know which way is the correct orientation?
Nope. Look again. Parts are labeled. LH is driver side. RH is passenger side.
Mine did not line up on my 2017. 50% of the holes did, the other 50% didn't. Didnt want to wait or exchange or any of that. Drilled the holes needed and installed. Irritating but looks 100x better so it offset the irritation. Thanks for the OP for posting.
