Clutch issues
Old May 17, 2019 | 03:14 PM
Beamer08's Avatar
Beamer08
Clutch issues
I have a 1995 f-150 with a straight 6 and a manual 5 speed all stock. It has a hydraulic clutch and I recently changed the master, slave, and clutch. Prior to doing that I was barely getting any resistance in the pedal. I’ve bled the system like crazy after the new parts and I can’t get any resistance in the pedal. If I push it down it just stays on the floor. Any suggestions?
Old May 17, 2019 | 04:13 PM
Killer79's Avatar
Killer79
The line bends up over and back down and the air gets stuck there very often. Happened to me, I had a mechanic bleed mine because I couldn't get that air out and I still have about an inch of play before it engages. I would try a bleeder that uses an air compressor.
Old May 17, 2019 | 09:32 PM
Beamer08's Avatar
Beamer08
I will give that a shot. Hopefully it will work for me. Thank you.
gatorfoot
Jun 19, 2015 06:40 AM
Frozen_Joker
17
Apr 10, 2014 08:06 AM
frederic
Apr 21, 2007 09:49 AM
racsan
1983 - 2012 Ranger & B-Series
Feb 7, 2005 09:14 PM
troubleshooter
Jun 15, 2003 06:53 AM
