any one know where I can buy a Door Jamb Pillar Assembly R H for a 1980 F 150 4.9 Custom Step side also known as Pillar Support the hinges bolt on to it
Can you take a picture of what you are looking for and how much of it as I may have a used one I can cut from my parts cab.
Also where you are as shipping might be high, it would coming from NC.
Dave - - - -
Dan,
I think he meant you hit the junk yard for that part can get it cut bigger than you need and trim to size.
Do you need the full part roof to rocker or say from the bottom of the glass to rocker?
I ask because the part I would have is from a truck that rolled over so the windshield post is bent.
Also if the post has rust and why you need to replace it, where is the rust and have you looked for a patch panel for it?
Who is going to replace this part you or a shop?
Dave ----
