1991 engine knock
Old Oct 3, 2003 | 09:51 AM
jimzettle's Avatar
jimzettle
Question 1991 engine knock
I have a 1991 f150, I6 300(of course). The other day I replaced the valve cover gasket and the upper intake to lower intake gasket which required the upper intake manifold to come off as well as all the vacuum lines and electrical connections. I disconnected the battery first just like the manual said. Everything went good. The next day while driving I noticed a knocking sound(doesn't sound like valve pinging). It only happens when the engine is under a slight load and a small range in rpm, or if I give it a little gas. Similar to what the EGR valve was doing before I blocked it off, except for the hesitations. It runs good otherwise. It ran good before I worked on it. Any ideas?
Loosenut53
Oct 3, 2014 02:53 PM
sitiakab
1997 - 2003 F150
May 29, 2012 05:50 AM
joseph8181
1983 - 2012 Ranger & B-Series
Jan 3, 2005 09:54 PM
rvpfly
Feb 22, 2004 03:58 PM
jimzettle
Oct 3, 2003 12:19 PM
