Remote starter
Old Oct 3, 2003 | 09:12 AM
2000F150EXcab's Avatar
2000F150EXcab
Remote starter
I am thinking of installing a remote controlled starter for my 2000 F150. I was wondering if anyone had experience with such an install. My truck already has a factory alarm, which is easy to bypass. I am mainly worried about having to disable any factory installed ignition kill features (like passkey).
Old Oct 3, 2003 | 10:16 AM
jimzdat's Avatar
jimzdat
Well, I can't say exactly what is involved in a Ford install, but I have installed remote start/keyless entry/alarm systems in both my Pontiacs, probably not much difference overall.
First thing: You get what you pay for! Yes, you can get a remote start for around $75 if you look at WalMart, etc. Unfortunately, they are not of very high quality, usually have low-amp relays integrated in the module (read: can't be replaced), and aren't as well featured.
I installed AviStart 3300 systems in both cars (made by DEI, www.directed.com) and while they were not easy to install (took about 6 hours each), they are of outstanding quality. DEI makes add-on modules to override most OEM security systems, some of them just splice into wiring, others require that you "hide" a key under the dash with the module to do the job--not sure about the Ford. The units I have come with a separate relay bank for all major functions that uses standard "Bosch" style relays, so if one does go bad, it's a $5 fix.
One of the hardest things (IMO) is just figuring out which wires to tap into under the dash--if you have a good service manual with a wiring diagram, it will save mucho time. The kits typically don't come with vehicle specific instructions, but if you go to a local shop that installs them, or www.bulldogsecurity.com they can usually get a list of what wires to tap, and where they are on the vehicle.
I picked up both my systems on ebay for ~$120 each; not sure what full retail is, but I think it was around $250. If you take it to a shop to get it done, I think most installs will run around $200-250 for labor, at least in my area.
All that said, I love these things! Nothing beats getting into the car in the middle of January, and it's already nice and toasty inside (also love that auto climate control) or in July have the car cooled down.
Good Luck,
Jim
Old Oct 6, 2003 | 07:35 AM
goofy173's Avatar
goofy173
check out bulldogsecurity.com. They have some information on that. They also have inline connectors for some vehicles making the install much easier.
Old Oct 15, 2003 | 01:31 AM
mazdatruckin's Avatar
mazdatruckin
I have a wire chart for this car, here's what I remember anyway..
If this isn't the superduty...
The car has 3 ignition wires
A 2000 model DOES have a transponder in the key, you will have to bypass the passkey system.
It isn't an easy truck to start with, a lot of work. But if you need help, we're here.
