Indiana is dead
RIP Indiana chapter of FTE
Only have 6 more windows to change out and 3 sides to reside with the hardi board.
As for my truck. It's in pieces as of this weekend. Was not my plan... Started out with an oil change and filters. The fuel filters was not packaged correctly and the O-ring kit was missing. So had to go back to the store. Figure I would get new rear rotors and pads since mine were noisy. Non of the part stores near me have the pads. I found some pads and headed back to the shop. Got the rotors and pads on, did my burn in runs. Started to head home and hear the pads rub the rotor when I turn and hit bumps.�� Got up Sunday and drove to church so I could go straight back to the shop. Picked up some calipers just in case I need them.. Got the truck up on jack stands and figure good time to rotate tires. I got the back ones moved up to the front and mounted. Started the truck up and put it in gear and watched the rotors go round. Discovered my driver side rotor is warped. Went and got the rotor changed out. rubbing noise is gone for the moment will know more once I get truck back on the ground and road worthy. I figure since I was having such a great day I'll try to figure out which pulley is squeaking. Well I managed to break my belt during the process. But did find I have 2 bad pulleys. one is an idler pulley and the other is the AC clutch pulley.
That is my drama at the moment.. Oh did order 08 mirrors they should show up this week. hopefully I can get it all back together before next Monday. Have a camping trip planned the following weekend.
I have done some upgrades since purchase of this truck. Blue fuel spring, 8 new injectors, new up pipe, new 4" straight pipe, 40 Atlas Ficm, EGR delete, and tuner with gearhead tunes.
