I'm not going to try to talk you into anything, but my 5.0 has been good so far. I had some oil consumption until I drove it hard for about a week and it has stopped. I guess I babied it too much. Other than that, its been powerful, dependable, quiet and gets very good mileage in my style of driving. It's hard to beat the sound of a V8 to old farts like me.
Thanks for starting this thread. I am also curious to hear about owner reports on the 2019 5.0. Have had a hard time finding complaints about it. In the market for one. We have a 2013 5.0 that has been flawless. And a 2007 5.4 that is high mileage and makes me nervous - looking at replacing it. Hope Ford got their 2018 issues on the 5.0 resolved by 2019 model year.
It seems that the consensus is not to break it in, but drive it the way you intend to from the start with a few wide open throttle runs in there after the first few hundred miles.
I have always gone out to a quiet country road after a couple hundred miles and done a few wide open runs from 0-80 or so, bedding in the brakes at the same time.
Yes, replaced the long block, but it took until 28k before the TSB came out.
Its in the shop now for high pressure fuel pump replacement, but I’m more concerned with the quart low on oil in 1,700 miles on this new engine. Time will tell if this is just “break-in” oil consumption, or if it’s the same mess all over.
It’s my opinion that the new 5.0L is going to go down as a crap engine all because of the plasma coating preventing rings from seating. I’m betting either major changes will soon take place, or the 5.0L mill will be replaced by a new design and displacement. I know others have had good luck, but I’m sorry... a cylinder wall that is basically aluminum like the engine on Billy-Bob’s Cub Cadet mower, does NOT say longevity or durability to me. For that reason alone, I’m out.
My dealer has been great, which is really the only reason I haven’t traded it by now.
I fully understand your pain. It is totally unaccepted to purchase a new vehicle to put up with this and have to explain problems to the Stealerships .Ford has a problem with this engine and the people who buy them are not happy. I have read the TSB and I would be pissed if they told me to come by every 200 miles(SO JODY CAN CHECK THE OIL. My 2018 has 7000 miles and was in at 4800 for a free oil change and tire rotation. When I got home I checked the stick with it being half way between holes. Now at 7000 it is near the lower hole.
I have a driveway full of fords Totally unacceptable...… TR
my 5.0 has been flawless. has not used any oil since new. I have always run new motors hard from new to set the rings. my father and i use to build motors together and if a new motor is going to fail you are going to find out in the first hundred miles. smokewagun before you give up on that motor. stick it in sport mode and drive it like a Porsche for two weeks you nothing to lose except a little extra fuel. After that see if your oil consumption stops. If not then trade it in on something else.
