Wandering
Old May 10, 2019 | 04:35 PM
billgrant's Avatar
billgrant
Wandering
My 1988 Super Duty 7.3 diesel wants to wander a little back and forth on the highway. I've put a new steering box in, new steering shaft assembly, had the tie rods checked and it still wants to wander. very annoying. Does anyone know if the spring bushings would cause this problem? If so do I have to remove the springs to put them in? Thanks bill
Old May 11, 2019 | 09:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes the spring bushings could cause this, and yes you need to remove the springs to press new bushings in.
also look at the shackle bushings inside the frame, they always get overlooked because they are not seen so are forgotten about.
Old May 11, 2019 | 11:10 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Could be a variety of different issues but worn out springs up front may be causing you to have issues also.
Old May 12, 2019 | 10:39 PM
TobyB's Avatar
TobyB
...or just too little toe- in.
You can measure with toe plates and 2 tape measures- you probably want 3/16" to 1/4"
toe in for stability.
Make sure to check after driving forward at least 10'- these trucks do odd things when you back up...
cheap and easy to measure.
t
Old May 12, 2019 | 10:41 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
t
X2 about driving forward. Good info.
Old May 13, 2019 | 08:21 AM
tjc transport
i ain't rite
if it is a F-SuperDuty as he said, it has a solid front axle in it. so driving forward after reversing will not do anything...............unless the kingpins are shot.
Old May 13, 2019 | 10:18 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
^^^ correct. I read past that it was a F Super Duty. That’s what I get trying to be cool and reply on my phone.
Old May 13, 2019 | 10:24 AM
tjc transport
i ain't rite
happens to the best of us Junior...........................
except me, cause i don't have a stupid phone. it is either the dinosaur desktop, or the new-fangled laptop for me.
Old May 13, 2019 | 12:09 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Hahaha. Hey if it gets the job done then stick with the desktop.
myblkex
Jul 1, 2009 06:32 PM
rmalottwtes30
Mar 6, 2008 02:21 PM
BOBSDIESEL
Jul 19, 2006 04:27 AM
86Broncho2gal
Bronco II
Sep 5, 2001 04:57 PM
Rosati
Jun 30, 2001 05:09 PM
