Sponsored by: Real Truck
gear ratio
Old Oct 3, 2003 | 05:29 AM
kmans777's Avatar
kmans777
gear ratio
Where can I find the rear axle gear ratio. The tag on the door is blank in the axle space.
2000/F-250/XLT/4X4/PSD/6 Spd/Longbed
Old Oct 3, 2003 | 06:30 AM
powerstroker250's Avatar
powerstroker250
On an F250 you should have 3.73's.
Old Oct 3, 2003 | 07:59 AM
Sport45's Avatar
Sport45
Check the tag on the axle look for 3.73, 3L73, 4.10, or 4L10. The "L" indicates limited slip.
Old Oct 3, 2003 | 06:17 PM
rclarke's Avatar
rclarke
Sport45 is correct about the axle tag. Often the first number of the ratio is under the bolt head. So if you see just 73 or 10 on the bottom line of numbers it is 3.73 or 4.10.
Old Oct 3, 2003 | 10:24 PM
johnsdiesel's Avatar
johnsdiesel
Without even looking, you have the 3.73 as powerstroker250 said. That's the only option for a PSD in an F250 or F350 SRW in the newer trucks.
