Oops Draind The Wrong One!!
Old Oct 3, 2003 | 02:12 AM
RIGBOSS's Avatar
RIGBOSS
89 F250 4WDFWHILE SON POINTED I THOUGHT HE WAS DRAINING THE OIL.. SEEMS IT WAS THE TRANSFER CASE FLUID.. JUST BEHIND THE PAN... WHERE CAN I FIND OUT WHAt to put back in it and how much.. and is there any online manuals out there?? w/ capacities and fluid types??
Old Oct 3, 2003 | 04:32 AM
kc73's Avatar
kc73
'89 f250 4x4. x-fer case: BW1356 4 pts. BW1345 6.5 pts. MERCON/DEXRON2 atf. more if you have a pto. this is from chiltons manual. simple form is get the atf mentioned above and fill to bottom of fill hole. it is good to change it anyway. others will chime in if they have better or more info.
Old Oct 3, 2003 | 08:14 AM
ecarter50's Avatar
ecarter50
Online manual.
