1993 f-150 6 cyl, 90,000 miles, extremely light duty treatment:
I have to press the clutch all the way down to get disengagement.
When I was in Reno, Nv, recently, at an altitude of around 6,000 feet, the clutch was nearly inoperable and I barely got home...but it worked again once I got nearer to sea level. I suppose the hydraulic fluid expanded a little at altitude...anyway, is there a way to adjust the clutch pedal throw? could this mean there is air in the line? I'm afraid to take in in and get the automatic line "oh you need a new clutch"...but if I do need service, any non rip off shops in the San Jose, Ca area?
thanks
stuart Horton
Do you have any leakage at the slave valve ? Thats the weak link in the clutch setup . How many miles on your truck ? The clutch disc , pressure plate etc will go a long time under normal use , the slave valves seem to die in the 100K mile range .
[font size="1" color="#FF0000"]LAST EDITED ON 22-May-01 AT 03:26 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 22-May-01 AT 03:22 PM (EST)[/font]
Hi Stuart, there should be an adjusting nut on the shaft between the slave cyl and the throwout lever. I agree with Paul as possibly replcing the slave cyl as you have 90k on yer ride. You could try bleed and adjust first to see what you have.
I'm not sure where to locate the adjusting nut on the shaft
>the throwout lever...also, what should I expect to pay for master cyl repair? know any shops I can trust in SJ?
thanks!
Stuart
>you have.
>Wayne
>http://home.pacbell.net/whomrig
Hi Stuart, I usually do my own work, so I can't make a good recommendation of a shop. as for the adjuster, it should be right by the throwout fork. Mine on my 60 F-350 is right over the rear bellhousing support. feel free to e-mail me if you would like.
