Hey diesel guys!
Old Oct 2, 2003 | 11:18 PM
Spectramac's Avatar
Spectramac
Thumbs up Hey diesel guys!
Just found this forum hanging out, on of all places, a jet boat board. Well, you gotta have a truck to pull the boat right!
I look forward to talking about 6.9s and 7.3s with you guys. I'm a 33 year old diesel mechanic and have worked on lots of Fords over the years. Right now I'm replacing a 6.9 in an '87 supercab that had an early ATS turbo on it. I have installed around 40 turbo kits on early Ford diesels (Hypermax and ATS mostly).
Hi all!
Old Oct 3, 2003 | 12:02 AM
dieselzen's Avatar
dieselzen
Hi Malcolm,
Guess I'll be the first to welcome you to the board. Glad to know you're a diesel mechanic. You'll should be able to help us get to know our engines and other systems in depth when you have the time to field questions. R.A.
Old Oct 3, 2003 | 11:26 AM
Fatshot's Avatar
Fatshot
Glad to have you here, Malcomb. I'm working on my first diesel and I'm sure I'll have plenty of questions as time goes by. I'm sure I won't be the only one either.
Dave
1994 F-250 7.3 turbo completely stock
Old Oct 3, 2003 | 11:36 AM
earlsfork's Avatar
earlsfork
Hi Malcolm,
Welcome! And thanks for your imput on my fuel/water separator question.
JW
1987 6.9L F250 4X4
Old Oct 3, 2003 | 11:42 AM
nogo73's Avatar
nogo73
sweet a diesel mehanic
Old Oct 3, 2003 | 10:23 PM
mrblacktop's Avatar
mrblacktop
Unhappy
i got a1991 7.3 man trans my problem is cold idle hot idle quit working can somebody help me out it dies every time i come to stop or slow down
Old Oct 4, 2003 | 12:42 AM
Spectramac's Avatar
Spectramac
How many miles are on your injection pump? Most idle problems are a result from a worn out pump. That is, if you don't have a simple fuel problem (air or a restriction).
Old Oct 4, 2003 | 10:05 PM
fordmudrunner2020's Avatar
fordmudrunner2020
Hi Malcolm
Welcome, eventually I may ask you some questions about my diesel if it ever has a problem.
Old Oct 4, 2003 | 11:17 PM
Spectramac's Avatar
Spectramac
Thanks for all the welcomes guys.
Old Oct 5, 2003 | 11:55 PM
FORD DIESEL's Avatar
FORD DIESEL
my question is for member who call himself {spectramc}have you check out the web site blue-oval-diesel.com, we are a local ford diesel club.
we are base out of western wa, we are always looking new members,, I;m only member with stock 7.3 idi engine,, all rest of members have 95 and newer powerstroke,
their only 12 really active members, their is 88 register members, so any one out their with ford diesel truck with in pacific nw please join our club or please just check are clubout,
we are having a october meeting this coming weekend oct-11-03 in bellevue wa at 6;30 pm. thanks James
Old Oct 6, 2003 | 10:29 AM
Spectramac's Avatar
Spectramac
I'll check it out.
Old Oct 8, 2003 | 09:58 PM
Greywolf's Avatar
Greywolf
Spectramac - this is too much of a coincidence to be true!
"I just happen to have one of them there thangs, RIGHT here on my truck..."
(Green Acres - Mister Haney)
Yep - an "Advanced Turbo Systems" (ATS) stuffer. And I have no background info on them at all...
Yessirree Bob! It's a turbo all right - but I don't remember ever hearing of ATS anywhere before. This should be interesting...
~Wolf
Old Oct 9, 2003 | 11:01 AM
Spectramac's Avatar
Spectramac
ATS has been around for a long time. They're out of Utah. A "stuffer" huh!
Old Oct 11, 2003 | 12:35 AM
jeryoder's Avatar
jeryoder
Hey, my truck is an '86 F250 Lariat 4x4 with the ATS turbo running on the 6.9. I Love it, but recently it started having trouble starting, when left set for a day or two. I need to crank for about 10 seconds, then it runs rough for 3 seconds, then it runs fine from there on. Is my mechanical pump the prob? Where can I find an electric pump to put on that is the right pressure, etc? Once it's running, it makes tremendous power. The turbo is faster spooling up than my dad's '99 Powerstroke. Can anybody give me some clues? Thanks!
Old Oct 11, 2003 | 10:17 PM
argve's Avatar
argve
jeryoder,
Could be your lift pump, but I would first look for leaks around the return line caps. If you look at these the wrong way the have a nasty habit of leaking. Might need a couple or so new orings. If no wetness is seen around the caps, then suspect the inlet to the injection pump. This is also a common area for leaks, there is an oring on the fitting inside the nose cone of the pump. Then check your pump.
To check the pump pull the scharder valve and check for proper pressure 4-6 psi, also check to good flow. I believe that it's 1/3 pint in 10 seconds of cranking. Also another old trick for testing a mechanical lift pump is to fill the output line of the pump with fuel. watch it, if it leaks down... replace the pump.
I run an electric pump that I picked up at Advance Auto. I don't have the part number handy right now, but if you go to my website and pull up my aux fuel tank page the information is there. I'm at work right now and can't pull up my website since it's not auth by the IT guys.
The cheapie pump that I'm running keeps up with the fuel system quite well. I have my injection pump maxed out and she never starves for fuel even while pulling steep grades with TT in tow. I think if I remember correctly the pump I have puts out 5-9 psi.
