1977 4x4 short bed build.
#46
#47
#48
#49
#50
#51
did you check tps with multi meter? pretty easy to check
have you put a vacuum gauge on it?
https://easyautodiagnostics.com/ford...sensor-tests-1
#52
#53
#54
Yes had to notch the firewall about 1/2 inch where it was pinch welded. The other option was to elongate the holes on the tower brackets to pull the motor forward and inch. The firewall was sacrificed.
He has the TC in and is making a mounting bracket from the donor truck. You are correct, The TC is tucked up in and rotated up on the drivers side 10-15 degrees to get the clearance. Hope to have the Tc finalized by next week with drive lines in. He has done this with a couple other builds so I am confident he will make it work.
#55
I dropped my engine in. Looks like the rear of the Windsor engine is 1" farther back than the 351M was. I'm going to cut new holes in the frame towers to move the engine front one inch. The AOD will mount using the factory cross member and mount from the C6. With the 205 transfer the front driveshaft will even fit. I think by going front the one inch I'll avoid any potential firewall clearance issues and there is plenty of room between the fan and radiator.
#56
It’s been slow going for a couple months, but finally getting back to working on it. Interior is pretty much done. Got a acc carpet kit and a seat from a 95 Eddie Bauer reupholstered and installed. New stereo, amps and speakers installed. Also dynamat and foam in.
Also refinished the headliner and overhead tray.
also made a “headliner” to cover the dynamat under the back window.
Need to get the ac lines run And get the transmission controller (us shift) connected and then it should be drivable.
#57
#60
