CAN ANYONE HELP ME OUT WITH INSTALLING FACTORY OEM POWER RUNNING BOARDS on my 2017 Ford F350, as to connections, wire harness, modules connectors,plugs etc..
Have you considered Amp retractable?
basically plug and play.
Theres wiring to create and a dozen PCs to buy individually to recreate the Ford setup...
My plan was to use all oem until I priced it out. I was a hair over 2000 not including pigtails and wire. I went to electricstep.com and went with amps delivered with stainless strip, and amp over ride switch for 1300 shipped. Works flawless.
Just got my override switch..will install this week...where did you end up putting your switch?
If u want to ask a question to a particular member click on their name and hit send a private message..Self explanatory from there...Ron, Forums are easy to use and maybe it's time you learned. There is a ton of valuable info here if your interested in taking some time to Learn!
I just want to ask a question to the forum .. Not a particular person, I just cannot find out what or where you go to ask a question.
I find nothing that tells me where I post so the whole forum can see and answer my question.
That simple, is all I am looking for
When you first enter here, look for "start new thread". Click on it and you will see what to do then. Don't get mad, just start checking things out slowly and it will happen.
