Emissions Help!!!!!!!!!
Old Oct 2, 2003 | 05:23 PM
gunrackgirl's Avatar
gunrackgirl
Unhappy Emissions Help!!!!!!!!!
PLEASE HELP!!!!!!!!!!!!!!
I just bought a really beat up '71 F-100 with a 390. Tried to get it to pass state emissions, but they're telling me it's smoking too much (which must be invisible smoke but we won't get into that) and that it's burning too much oil (which must be the oil with the level that stays even all the time, but we won't get into that either). I don't wanna rebuild this motor right now, but I do want to get plates on it. In Colorado, if I can get it to pass once, I can get special plates that allow me to NEVER HAVE TO GET EMISSIONS AGAIN.
Other than this, the thing runs like a champ, and while the motor will be rebuilt, I just can't do it right now.
Does anybody have any quick-fix or temporary ideas to get that smoke down without venting it elsewhere? I'm a Mopar person and this is my first Ford... I'm learning that things are very different on this side of the fence!
Any help would be soooooooooo appreciated!
Thanks,
Kristen
Old Oct 2, 2003 | 05:32 PM
CRJ900's Avatar
CRJ900
Where do you live. Since it is a 71 the emissions law should not apply to you.
Old Oct 2, 2003 | 05:42 PM
BB's Avatar
BB
Change the oil and put in straight 40W along with two cans of CD2 treatment (the one for for oil burning).
Barry
Old Oct 2, 2003 | 06:07 PM
gunrackgirl
no CO emissions?
Well, the oil was just changed, but I haven't tried the additives yet. Thanks for the suggestion!
I live in Colorado. You've got to get it to pass once, then you can get "collectors plates" and as long as you keep them renewed you won't have to get emission after that. Unless you know something I don't know.....
Old Oct 2, 2003 | 07:59 PM
Comegetsome's Avatar
Comegetsome
Is it a visual test you're trying to pass? If so, there's really not a lot that can be done to hide an oil burner.
If you feel really brave, you could mix in some 90W into your oil to thicken it up. I'm not sure if I'd do that, but I have heard of other people doing it.
Old Oct 3, 2003 | 10:54 AM
gunrackgirl
Apparently it's the visual. It passes the numbers fine. I'd like to see what criteria they use for the visual, because it's not bellowing black smoke or anything. It hardly smokes at all, but where the tailpipes extend the panels do get a nice cover of soot. But, so does my Dodge, and it passes with flying colors.
I'm trying to find somebody in the next county to let me use them as a garage address so I can get past this whole nonsense.
It's almost 34 years old! Of course it smokes! It's a grandpa.
Old Oct 3, 2003 | 10:55 AM
gunrackgirl
hotter spark plugs
Somebody else advsd running hotter spark plugs in addition to heavier weight oil for the test... anybody tried this?
Old Oct 3, 2003 | 12:04 PM
kevin71100's Avatar
kevin71100
Maybe there is a "tune-up shop" very close by the Emission Station that will analyze your exhaust and set your carb to pass the emission test for a few $$ then after passing the test will reset the carb to run the best. The state guys hate these shops but who cares?
Old Oct 3, 2003 | 12:24 PM
dotcentral's Avatar
dotcentral
Are you getting the engine warm before taking it in? Anytime I've had to take a car in for inspection, I tried to run it for about 15-20 minutes on the highway first. I know you said your problem is visual, but a nice cruise might help clean it out before letting it idle at an inspection station. Probably washing the soot of the bed might be a good idea too.
Leroy Unlisted
65
Sep 19, 2016 11:02 PM
Powersmokin137
15
Aug 25, 2016 07:32 AM
Macrobb
17
May 29, 2016 10:30 AM
D8chumley
2009 - 2014 F150
20
Apr 28, 2013 06:56 AM
JBronco
1978 - 1996 Big Bronco
Mar 21, 2013 02:32 PM
