Sponsored by: Real Truck
Parking / Work surface
Old Apr 20, 2019 | 10:04 AM
Bigdukesix's Avatar
Bigdukesix
Trailering
Hello out there!
I have a unique situation. Where I live, the HOA will not allow work on a truck (2008 F350 Diesel 4X4) in the driveway. So, I live near Vegas although I have RV access to the backyard it is covered with the typical desert pebble landscape with sand underneath. The sand is compacted but I need to lay down some sort of surface to park the truck, jack it up and work on it. My options, at least in my mind, are concrete pavers (expensive) or double sheets of 3/4 plywood, or pavers with single sheet of 3/4 plywood on top. Any thoughts or suggestions would be most welcomed. PS.Can not pour a concrete slab...don't ask:-)
Thanks in advance
Old Apr 20, 2019 | 11:26 AM
seville009's Avatar
seville009
Why not just get something like a few 10’x8”x2” pieces of pressure treated lumber and cut them into sections to place under each wheel and jack/jackstands. When you’re done, much easier to pick up and store. If you’re concerned about spills or dropping stuff, buy a plastic tarp to put under your work area then throw it away when you’re done
Old Apr 20, 2019 | 09:47 PM
SuperDutyScaler's Avatar
SuperDutyScaler
One sheet of 3/4 plywood is all you'll need. For the jack stands I would use a 2x12 under it to support the legs. Personally I'd weld a big plate to the bottom of the legs
Old Apr 21, 2019 | 08:15 AM
Chuck's First Ford's Avatar
Chuck's First Ford
NOT unique situation...
I know of NO "55" and over park that permit... wrenching on vehicles..
I use the out of business gas station down the street.. its not roped or fenced off...
no getting "Caught" working on truck... depending on the "LEGAL" paperwork.. you could be forced to move...
I have seen people wrench on there stuff.. at the rear of "Walmart"s... do not make a mess..
oldford65
Garage & Workshop
27
Feb 16, 2014 12:19 PM
stryder
Garage & Workshop
Feb 28, 2009 06:29 PM
rocky35
Garage & Workshop
47
Jan 27, 2007 06:16 PM
Primered86XLT
Garage & Workshop
15
Feb 3, 2005 11:55 PM
maa139
Garage & Workshop
Dec 30, 2003 10:11 PM
