C6 into 66
Old Apr 16, 2019 | 08:28 PM
Jimmy nz's Avatar
Jimmy nz
C6 into 66
I'm thinking of putting a c6 from a 74 pickup into my 66 lwb f250.is the drive shaft from my existing manual the same as an automatic one thanks
Old Apr 16, 2019 | 10:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jimmy nz
I'm thinking of putting a c6 from a 74 pickup into my 66 lwb F250.
Is the drive shaft from my existing manual the same as an automatic one?
... No ...
Old Apr 16, 2019 | 10:37 PM
resonateur's Avatar
resonateur
Jimmy:
chances are you will need to have a custom drive shaft made to your application, or have the forward driveshaft from the 74, modified for your truck. You may be able to use the rear shaft from the 66, but the 74 shaft has a larger diameter and you might prefer that. Those are my recollections from when I made the same swap, but measuring will show you what you need to do.
67F250RET
Mar 8, 2013 09:10 PM
vincel1965
Nov 20, 2012 09:50 AM
1975MudRat
Jun 10, 2012 10:09 PM
red68ranger
May 9, 2000 04:53 AM
