Long term, high mileage 6.7s stock or d*****d: how many miles and if original HPFP and injectors
#31
Okay then, I've been corrected. That's what I've read they go by also. I posted up these pics from
https://www.dieselsite.com/dieselsit...separator.aspx
ABOVE LEFT IS THE FORD SERVICE MANUAL PICTURE DETAILING WHAT THE TECHNICIAN MUST LOOK FOR. BOTTOM RIGHT IS WHAT MINE LOOKED LIKE WHEN REJECTED FOR WARRANTY. I believe this is from the DFCM; maybe inside the cone shape in the upper part of the DFCM.
THIS IS A VIEW INSIDE THE TOP OF THE INJECTOR. RUST IS VERY EVIDENT.
YOU CAN SEE THE DEBRIS IN THE SCREEN ON THE REGULATOR IN THIS PHOTO
THIS WAS A VIEW INSIDE THE FUEL PUMP. WE TOOK THE HEAD OF THE PUMP OFF TO SHOW THE CONTAMINANTS.
Here is the link to the General Service Bulletin for the 6.7 Powerstroke Diesel Fuel Conditioning Module (DFCM) for FYI:
https://static.oemdtc.com/GSB/G0000035.pdf
#32
I had a July 2010 build truck, I ran it 150,000 miles and bought a 2015 truck. I replaced, front hubs, exhaust sensors, and the turbo coolant and oil connectors, But nothing else.
Like others, I change the fuel filter every other oil change, I run Opti-Lube occassionally. for extra lubrication and anti gel ( in colder months) and usually buy fuel from high volume stations
#33
Yeah my 6.0 used to look like that too. All diesel fuel attracts water, its inevitable, hence why trucks have a water separator. It's ridiculous that Ford uses this fact as a way to deny warranty coverage, I really hope they get burned on the class action suit, and I don't see any reason why they wouldn't if the lawyers have their story straight.
Diesel fuel is highly hygroscopic which means that it readily absorbs water from the moisture in the air. Water contamination in one of the biggest concerns with diesel as it leads to the corrosion of the steel components in the fuel injection system, as well as it promotes microbial growth in the fuel tanks.
https://www.the-triton.com/2016/03/w...s-worst-enemy/
I agree with you on Ford's position to deny warranty coverage. What if you bought fuel with excessive moisture that over stressed the DFCM and had no WIF light? The opinions here are many on this. The answer of "just buy quality diesel" and "high sales place;" does that guarantee you won't ever have a problem? How do you know that the fuel you are buying is high quality and does not have entrained or excessive water in it without sampling? Does everyone who doesn't worry about moisture use additive and/or drain the DFCM frequently? Do the guys that don't drive their trucks frequently know that just by the temperature difference from day and night, that the condensation which forms in said tanks because of said temp differences, will make it's way into the fuel? These are all rhetorical questions in nature. There's no need to answer them...just thinking out loud. I might just start a fuel thread...
#34
#35
For the fuel, don't let it control your driving of the truck, just be mindful of the extra maintenance. Stick to high volume stations (fuel turnover). If you want to take it further, learn your local stations, keep or snap a photo of your receipts, use an approved fuel additive if you choose and just drive and enjoy your rocket ship of a truck. To further put your mind at ease, proactively ask your insurance provider if they cover fuel system damage from bad fuel since you can't lab test the tanks in the ground each visit (that would be silly).
Attached is an example about learning local. I filled up at a convenient to me Shell station near my office when I purchased mine in 2010. After the first filter change around 15k, this picture is what I noticed.
Reading others comments here were saying their filters look new at 15k. So, as a long term experiment, I drove further to a different Shell most of the time. After 15k, my filters were clean. I tried the first station on and off again over time and the algae (or whatever it is) was back.
A friend (with a Duramax) reported similar results, up to learning their fuel tanks had obvious "crud" issues (a co-worker was having issues with his 5.0 Mustang). This was a busy Shell. School buses, Army vehicles, fleet trucks, yard dogs, etc. filled up here but turns out, crap tanks.
Of course my "experiments" have various additional stations used from traveling but a majority of fills were at home. I've not used that location since and I've not had a problem since.
I've even had issues with my tractor where a (different) station had obvious fluctuating water issues with their off-road diesel tanks. One particular tank I had received was bad and after stopping for a break one day while brush cutting, I noticed the water separator was half full of water which was all fuel prior to starting a few hours prior. I again switched to a different station for off-road diesel where I don't have this water issue.
#36
#37
Kper, I fill at only high turnover stations, both are Shell. In this town half the vehicles on the road are trucks, and half of those are diesel. Diesel at every station, but the two that I frequent are at either end of the town, close to the interstate and the close to the highway coming in from the other side.
I used to drive long haul, keeping an eye on water/fuel filters was par for the course and I filled where I needed to and otherwise didn't much care. This was before DEF and EGR.
Don, I've sold guns for the same reason. I fixed them made sure they were perfect, and sold them with full disclosure to the next person. I can't say I blame you. My goal is to just have a truck paid off and do what it takes to keep it going.
#38
There are a number of HPFP threads here. Some with heated debate, thread closures, even a member ban or maybe two. You don't want this to go that far.
I've always considered myself an analytical thinking. I'm not trying to freak anyone out and I ain't skeered... Just posting up stuff for people to think about. Read it or don't, think about it or don't. No worries.
Thanks for posting up, pal. That's good to hear. Just one question though: what made you trust the new 16 with the same pump design as the 15? I'm just curious to your line of thought. Thanks.
#39
168K on my 2011 6.7, HPFP, and injectors are original, same with the DPF...I run Power Service diesel kleen, or Howes diesel treat...but not every fill up...my truck has been known to go on a few fill ups without additives..either because I forget to buy the stuff or I just don't feel like getting it out of the toolbox..also I went over the fuel filter change interval by...a lot....a few years ago..last time I changed it the filter was still pretty clean and no sign of "glitter"
#41
2015 here, 146k hard miles. radiator replaced 3x (warranty), vacuum pump (oil leak), everything else original. deleted with PPEI tuner. Oil changes every 9-10k, fuel filter every ~20k, and prime the filter 6 times before starting. about 2k idle hours.
one thing to note is i had a titan fuel tank put in and for whatever reason the truck wouldn't reprime. took well over an hour of cranking which included draining both batteries, having a jump vehicle, etc before it finally started.
serviced transmission twice, axles once and tcase once or twice. original brakes.
#43
#44
#45
Thanks for posting up brother. Kinda curious on your thinking that you did not trust the 15 but you trusted a new 16 with the same fuel system? Thanks.
