Sponsored by: Real Truck
Won’t crank
Old Apr 12, 2019 | 06:15 PM
dondolittle2's Avatar
dondolittle2
Won’t crank
Hello everyone I have my old 2004 6.0 I purchased in 2010. I deleted the EGR, placed a remote oil cooler on it (did away with the internal oil cooler) drove it for six years then let my son drive it for a couple of years. My problem is.........
the other day my son was driving it and all of a sudden it quit. What or how do I check it out since it doesn’t have a spark I can’t check for firing, it has fuel will turn over but no crank and run where do I start?
Old Apr 14, 2019 | 09:52 PM
Colorado350's Avatar
Colorado350
What gauges do you have? Fuel pressure, good?
I’d start with electrical systems, grounds, fuses, chaffed wires etc...
Old Apr 15, 2019 | 11:01 AM
99f350sd's Avatar
99f350sd
Get it to a diesel mechanic if you trust one...You dont want to make anything worse.
Old Apr 15, 2019 | 01:03 PM
chukeeee's Avatar
chukeeee
You say that it will turn over, but it won’t crank. Aren’t those the same things?
Old Apr 16, 2019 | 03:02 AM
ZackV54's Avatar
ZackV54
He means “Crank no start”.
Old Apr 16, 2019 | 03:04 AM
ZackV54's Avatar
ZackV54
Do you have a scan tool so you can see ICP Pressure, FICM Voltage and Sync, and IPR %?
Old Apr 20, 2019 | 07:52 AM
dondolittle2
I have the Scan tool from Auto Zone but I don’t have any of the ICP pressures, FICM Voltage values. Thanks for comments
Brian Carter
Mar 14, 2016 08:53 PM
softpickle
Jan 23, 2015 07:45 PM
peteandangie2
Sep 3, 2014 09:45 AM
675doug
Nov 14, 2013 09:13 PM
Frankiea87
Feb 8, 2012 09:36 PM
