New Engine Block Heater Recall: 19S11
Just saw this pop up, looks like Ford is just going to cut the engine block heater cable off until they come up with a new cable design. Apparently, if you've had your truck inspected as part of the last recall to look at the cable, Ford might have inadvertently damaged the splice.
“Dealers will disable the vehicle’s engine block heater cable by cutting off the plug end prongs and sealing the end cap with silicone sealant. Customers will be notified when an engine block replacement cable is available"
How about just don't use it until they have a replacement ready. No way am I having them complete this new recall. SMH.
I'll have to take a look to confirm, but I don't think they cut mine off.
They did the original inspection in February (I think), added some sealant and ordered some parts. Last week when I was in for service they told me that the recall had been changed and additional parts would be required before they could actually perform the repair. They didn't mention anything about cutting the power cord off.
Finally a service procedure that the techs can't mess up!
Money saver too... If u have block heater but never use it for what ever reason...you won't bother having it fixed. Also, bring it in so we can cut off plug! If we don't go in and there is a Fire... Not Ford's problem... we didn't bring truck in for recall.
Received 6,693 Likes
on
One of my kids tried to talk me into moving to Alaska. When I learned he had to keep a toilet seat inside his cabin so his butt wouldn't freeze to the seat in the outhouse, I moved to Hawaii instead.
I would hope that Ford prioritizes where they send the parts kits for this action.
Its not claiming to be a fix, its Fords way of making sure some ******* doesn't plug it in (and possibly start a fire, etc.), .......until a fix is available. Then it will get fixed properly with an updated kit.
