2016 F-350 6.7 Engine Warranty Denied
As the title states a Ford dealership has denied a warranty claim for a blown engine. The truck has 48000 miles and was purchased less than a month ago from a Ford dealer. At the time of purchase the truck had 31000 miles.
The truck is sitting at a dealership in Texas and I live in Virginia. The driver stated the engine shut down after about 3 miles of driving and warm up (after an overnight stop). The dealership initially said the oil filter adapter gasket was leaking and that was what caused the oil to blow out and shut the truck down. Then they said it was a blown oil filter gasket and took pictures of the blown gasket. Said that it would not be covered by warranty. There were no DTCs that I am aware of. The service advisor was not very helpful, and the service manager has not returned my call. I called the Ford line (800-392-3673) and was told that Ford will take the recommendation of the dealer. I said I did not accept that answer and I am now waiting on a call from a customer service representative from Ford.
I guess I am looking for some info on how to get this right with Ford. I believe it should be a warranty claim.
If I am being unreasonable about expecting Ford to warranty the engine please let me know.
So, who did the last oil change? Have you contacted the selling dealership? Do you have documentation of the last oil change? That's where I would be going instead of the Ford reps. They would be the last resort after I had my way with the selling dealer or the shop that changed the oil. JMO
We do our own preventive maintenance (we are former Marine mechanics). The oil was last changed at 39000. The first pic is the failed oil filter gasket. The second pic is the adapter gasket (originally what the dealership diagnosed). Engine isn’t locked but according to dealer no compression.
Brief conversation with selling dealership. Once I get invoice from Texas I am going to send all documentation (pics, invoice, oil filter receipts) and see if my local dealer will honor warranty.
Best to fix that issue internally within your oil change guys.
senix,
You are correct, sir. I was a bit emotional at first over this episode, but having had time to cool off and look at the facts I do believe this was a multi-tiered mistake.
Again, thanks for everyones input and advice. Good to get input from individuals that are not emotionally and financially tied to a problem.
As a now retired mechanic who serviced vehicles for over 40 years I can't tell you the number of times I've seen a old oil filter gasket left in place that didn't blow out but also have seen techs miss the old gasket and have it blow out leaving their stall right after the oil change. That is one expensive oil change mistake if thats what happened here!
have truck towed back home..... to local dealership... start over with Ford...
Manufacturer... goes by dealership word first... so change dealerships...
not cheap or easy.. but maybe a second chance... different eye's and views of mind....
fyi.. short block or long block.. can take one to two months... first once Ford said OK... dealer needs to collect 10 to 13 photos of truck ID numbers... and some disassembly required.
Ford way of protecting itself from dishonest dealers...
this I have read of owners that did get the "OK" on a replacement engine under warranty..
