any suggestions?
Old Oct 1, 2003 | 09:57 PM
redfish508's Avatar
redfish508
any suggestions?
I have a 96 Explorer with a 302 (5.0L) with 98K miles. It has been an excellent vehicle and has never been in the shop. The check engine lite has been on for seven years, since the vehicle was 6 months old. It runs like a top and passes tailpipe tests with flying colors. My question is: What is the best way to disable the check engine lite? It is obviously not going to burn out, and I'm tired of looking at it after seven years! Love your forum! Thanks for any suggestions.
Old Oct 2, 2003 | 04:24 AM
marragtop's Avatar
marragtop
Does disconnecting the battery for 5 minutes cause the light to go out(even for a short period of driving)?
Old Oct 2, 2003 | 06:15 AM
bcjim's Avatar
bcjim
In 7 years you never asked the dealer to figure out why the light is on??
Old Oct 2, 2003 | 07:52 AM
FortyFords's Avatar
FortyFords
Thats got to be a record of some type !!!!:-staun
Wow ! hows the fuel mileage been ?
Does it idle smooth?
Can you imagine what the egr ports look like ?
Take it to autozone an have it scanned just for
Ha ha's and let us know what the codes were?
They'll do it for free
yes as above reset the light by disconnect battery
but it will come back ,unless malfuntion is fixed
as stated.
Wow 7 years!!!!!! did you put black tape over the light like some people do ???
Rich
Old Oct 2, 2003 | 07:25 PM
JPC's Avatar
JPC
Take the dash apart and pull the bulb out!
Old Oct 2, 2003 | 09:12 PM
redfish508's Avatar
redfish508
any suggestions?
Thanks for the comments. Yes, I've used tape to cover it up. Yes it idles smooth and gets 17mpg. When I said it's never been in the shop, I mean it has never malfunctioned! You put the key in and it starts up and runs great! Never failed to do that in seven years! Of course I have done routine maintance. (fluid and filter changes, plugs @ 50K miles, tires, and battery changed out once). The lite comes right back on as soon as you reconnect the battery and restart the vehicle. I've had the codes read three or four times and everybody gives me a different story on what caused the lite and what would be involved to make it go out! I realize I can take the instrument panel out and attack it from the front. However, I've done a little interior work where removal of trim was required and it was not fun....when it was time to put everything back together. Does anyone know if I can disable the lite by clipping a wire in the back(and if so ...what wire?) or does the I/P use LED illumination? Thanks for the assistance.
