Sponsored by: Auxito
ignition switch?
Old Oct 1, 2003 | 05:22 PM
artvan's Avatar
artvan
Unhappy ignition switch?
i turn the switch forward and all i get is a clicking in the fuse box.i can turn the switch backwards and the radio ect. work fine.when i try to crank the truck again i just get the same clicking and all my preset radio stations are cleared like i unhooked the battery.this is a '97 f150 and the battery is fine also changed the fuse that was clicking.i read another post and found out how to remove the switch.
Old Oct 1, 2003 | 05:26 PM
stepman's Avatar
stepman
This may sound dumb but, have you cleaned the batt cables?
Old Oct 1, 2003 | 06:02 PM
triton_2002's Avatar
triton_2002
Yeah, you're not getting enough juice to crank the engine. You're battery may not be totally dead, but it needs to be recharged or replaced. I had to replace my battery because it was not holding the charge and its a '02 F-150
