Recommendations for not snapping bolts on EGR
Input and advice greatly appreciated what did you do with removing these bolts to avoid them from snapping during removal .And if they do snap what did you do? Going to be removing it and have the kit for full removal but just trying to think I had of what ifs. Thank you
Haven't begun the process yet just thinking ahead ,I know if they snap to tap and die it out but I want to avoid it what are people's techniques they've used for removing this I necessary thing . I've heard of people if they've snapped a bolts they don't even bother that they just twist the block off plate a little bit clockwise and drill new holes with treads . Just want to do it right and keep it as clean as possible
I used kroil, amazing stuff. I sprayed the bolts down every time I shut the truck down in the garage, once they cooled a bit but still had some heat, for about two weeks before I touched them. Figured it would creep into the threads as it cooled. Take the easy to access egr pipe off first if you are doing the full set of blocker plates, it will give you a little more room to maneuver. Came out super easy after they initially broke loose. My truck only had 22,000km thou, that's as long as I could stand that bull**** emission system, has run absolutely amazing ever since. Do your research on tunes thou and go with a big name tuner that has done thousands of powerstroke tunes, not some local "expert" diesel shop that some local recommends. I also pre soaked the egt probe I was planning to remove out of the exhaust for the egr plate reading. Good tuning is the single most important piece to the puzzle imho. Flash your delete tune prior to removing everything, unplug a sensor on your exhaust, and start the truck and make sure it idles and doesn't throw any codes, but don't drive it like this, then remove everything once you know the tuning is good. Also hook a battery tender up prior to flashing to make sure batteries are tip top, as low voltage during flashing can cause problems
Ive snapped one before. Easy outs/reverse bits were no help, so I tore the top end down and installed a new exhaust manifold ($40). Won’t break another one.
ngng
6.7L Power Stroke Diesel
19
07-08-2014 08:56 PM
nhfire 77
05-07-2004 07:08 PM
