2012 radio replacement
Old Mar 29, 2019 | 12:32 AM
maxtor's Avatar
maxtor
We have a 2014 Jeep Rubicon that has a radio that uses a usb port to access songs on a flash drive. We just purchased a 2019 Kia that also has a usb port for a flash drive.
My question is, what upgrade is the cleanest to replace the stock radio and cd player on our 2012 PSD. We have 1 tb of songs on a flash drive while the same amount of songs fit on over 24 cd's.
It is much safer not having to replace cd's on a long trip.
I want a radio that looks like it came from the factory. Also need to be able to pair with our phones.
btw,,,, just checked our odometer and it just passed 19k. I need to drive it more.
We have other vehicles, and our PSD is by far the most comfortable on a long drive, although we have only 300 miles on our Kia, so don't know how it will be on a long drive.
Old Mar 30, 2019 | 02:42 PM
slorider's Avatar
slorider
Which trim level/radio is currently installed? I take it you don't have the SYNC system? Crutchfield has a good "Find what fits your car" feature so you can see some options for your specific vehicle.
Just a little off topic, 1 TB (terabyte) would be equivalent to 1,248 CD's.
Old Mar 30, 2019 | 11:46 PM
maxtor's Avatar
maxtor
None of their radios fit my pickup. Rats.
Old Mar 31, 2019 | 11:37 AM
slorider's Avatar
slorider
Hmmmm... I'm pretty confident they have one that will fit.
Using the following specs they have 153 stereos that will fit:
Your vehicle:2012 Ford F-250 Pickup Regular Cab
Options:with AM/FM/CD player; Without SYNC System
Old Mar 31, 2019 | 03:13 PM
Boaterguy's Avatar
Boaterguy
Isn't it a standard double DIN radio, such as the non touch screen, factory one in my XLT?
Old Mar 31, 2019 | 04:14 PM
maxtor's Avatar
maxtor
Our truck is a 2012 F250 XLT Diesel Supercab 8ft, bed, with sync non touch screen. AM FM and CD
Old Mar 31, 2019 | 06:07 PM
Boaterguy's Avatar
Boaterguy
Well, if it looks something like this, it's a standard double din radio. Places like crutchfield or sonic electronicx ask for vehicle info so they can send you the right mounting kit's, wiring harness adapters etc. You can even get a harness that will allow your steering wheel radio buttons to continue to control your new radio.
Old Mar 31, 2019 | 06:08 PM
Boaterguy's Avatar
Boaterguy
Old Mar 31, 2019 | 07:18 PM
slorider's Avatar
slorider
Since you have the SYNC system, do you have the input located right next to the glove box?
Old Mar 31, 2019 | 08:24 PM
Oldyella66's Avatar
Oldyella66
I recently replaced the radio in my 2012 F350 with a kenwood carplay unit. Was a pretty straightforward install, aside from my determination to make everything look factory.
My truck is 2012 King Ranch, had the standard AM/FM/CD head unit with sync. I was able to keep everything functional with the Maestro RR, and Maestro wiring harness.
Old Mar 31, 2019 | 09:44 PM
maxtor's Avatar
maxtor
I can't believe it......... Yes I have the input near the glove box.... I purchased this truck new in 2012 and never saw it. Looks to be a usb port. I will try it out. The odometer reads 19,085 miles. I guess I better drive it more. I will try it out and see if it will play music from my flash drive.
Just inserted the flash drive in my usb port by the glove box and my radio will not play the mp3 songs.
Old Apr 1, 2019 | 03:44 PM
maxtor's Avatar
maxtor
FINALLY
After calling two Ford dealerships, and they said it would not work, I did not give up. I kept playing with it and here is what you have to do.
1. Insert flash drive into usb port.
2. Press voice button on steering wheel.
3, Tell computer to "connect usb"
4. Tell computer to "play all"
5. That's it..... enjoy your mp3 files on your radio.
Flash drive has to be 32gb or less, also must be formated for FAT32.
Old Apr 2, 2019 | 01:08 AM
maxtor's Avatar
maxtor
You are correct,,,, I should have said my 24 cd's came out to just under 1 gb of mp3 files, Not 1 tb.
So even a 8gb flash drive would be enough to hold around 192 cd's.
intruder1239
Feb 13, 2012 08:50 AM
jthomp03
Dec 4, 2007 11:56 AM
kaleyos
Dec 17, 2006 05:41 PM
makthenif
Jun 12, 2006 08:37 PM
brianas
Nov 26, 2003 03:59 PM
