Blue spring problem
Old Mar 27, 2019 | 09:41 PM
Bluef2.5.0's Avatar
Bluef2.5.0
Blue spring problem
I was looking to see if anyone had a answer to this weird problem! I have a 06 6.0 and I put a blue spring in it. Before I was getting 13.5 mpg for 2-3 weeks after I was getting 16.5 mpg now I’m back down to 13.5 any guesses? I haven’t checked fuel pressure yet and was thinking it was a pump but it wouldn’t go up at all if it was a pump, correct? I’m lost as to why it would go up then back down
Old Mar 28, 2019 | 07:17 AM
navistarnut's Avatar
navistarnut
Curious, did you actually hand fill and check MPG?
Or are you going off the display?
Every 6.0 owner should have a way to check fuel pressure IMO, but at any rate, I would run another tank or two so you have more of a baseline to rule out any calculation mistakes
Old Mar 29, 2019 | 08:04 PM
Bluef2.5.0's Avatar
Bluef2.5.0
I did it by hand. I filled up last night and got 15.5 so it’s all over the place. My driving hasn’t changed any. I need to do a fuel pressure gauge. That’ll be the next mod for sure!
Old Mar 30, 2019 | 02:54 AM
Euroman's Avatar
Euroman
Makes a big difference to me how the truck is leaning at the pump. I get more in when the drivers side is lower.
tofargone
Dec 16, 2019 12:45 PM
David Fehir
Jul 19, 2019 06:56 PM
2003 EXCURSION
Jul 31, 2016 06:56 PM
WatsonR
May 19, 2014 08:14 PM
FordT444E
Apr 28, 2012 11:16 PM
