My 1963 F-350 Flatbed Dually
AXLE 29 = Dana 70 / 5.87-1 / 7,400 lbs. Rear Axle Capacity.
Some 1961/62 F350's have Timken B140 rear axles, some have Dana 70 rear axles.
ALL 1963/84 F350's have Dana 70 rear axles except 1979 F350 4WD that have Dana 60's front & rear.
No F350 of any year came w/a Rockwell rear axle.
It's hard to say what has changed in the last 50+ years. The warranty tag describes a 1963 F350 equipped with the standard Dana 70. Could be sheet metal moved to an older chassis/drive line or the axle was switched. If the tag in post #7 was removed from the rear axle of the truck in which the warranty tag was posted then the OP should refer to that axle as a Timken axle not a Rockwell. The stylized "TDA" triangle is Timken Detroit Axle the tag is clearly stamped B140 this series axle would be correct for a 61-62 (probably back same back through the 50's).
abe
19
03-21-2017 11:01 PM
abe
08-19-2014 02:30 PM
SaikotikGunman
15
06-09-2009 10:56 AM
