Beehive Oil Filter
Beehive Oil Filter
My truck is fitted with this Beehive style oil filter. I have searched the internet but cannot find much information. I want to do an oil and filter change. If I remove the sump plug will the oil in the filter drain down also ? How do I get to the filter ? do I place a screwdriver into the hole at the top and just spin it loose ?. Had a quick go at that, but if that is the process it is on there very tightly.
Suffolkman
Suffolkman
It does appear that's a "nut" that clamps the lid, but it looks pretty weak to me. Go carefully! There are a couple of different brands/types, some info and pics here: https://www.fordbarn.com/forum/showt...beehive+filter
This could actually be the source of your low oil pressure situation. On the Ford type stock bypass filter, there is an 0.060" orifice in the oil line to the filter. These beehives don't appear to come with that orifice, although they have small holes in the center tube that do restrict flow somewhat. Try plugging off the supply line to the filter, see if your oil pressure improves noticeably.
PS -- an original beehive as yours appears to be is worth quite a bit to the traditional rodders.
Hi Ross, I don't think this is going to be original (although I cannot be sure). It does look identical to the Speedway unit. I have got to wait a day or two for the new filter, so perhaps I could take the Beehive off and look at it properly. So you are saying that the hole in the inlet maybe to big ?. I wonder if a reducer is available...I am sure I saw one somewhere online.
Just lifted this text from the Q&A's on the Speedway site for their Beehive,,,,,,"The best location for your Offenhauser Fifties-Style Beehive Oil Filter, is to mount it on the firewall. The inlet or pressure side is fed in from the bottom. Just in case you don't know this filter is manufactured for a "flathead engine" that is why it has a restrictor hole in the center of filter housing body"
Suffolkman
Suffolkman
