Maybe try a junk yard search engine, or take your bad one to a machine shop?? Maybe they could fill in and drill and retap the bad one. Even if they had to use a different bolt......
More extreme is find a cheap donor truck that has that bracket and possibly some other parts you could need in the future
My search so far says those brackets have been hard to come by for a long time now. Part# 2B292?? See pic
Thank you for the reply! I have another question. What goes between the axle and the hub to keep the hub oil from leaking out?
sorry I haven't gotten that far on mine, my guess is a seal, that on mine ,I can see a ring hanging behind the backing plate on each side... I only got new windshield, front brakes up to snuff, midship fuel pump, and fixed horn so far... working on washer fluid pump not working, and the sloppy shift column and broken PRNDL. Rear brakes are after that.
