Electronic Issues, 2014 F250 powerstroke
I am currently having some sort of electronic issue with my 2014 superduty powerstroke. I lose my ambient temperature read out. I just get three dashes where the outside temp should be. I also lose, part of the time, all the power to my radio, my fan to include heater, defroster, and my air conditioning. I also lose my key fob unlock function I also get a false reading from a tire sensor. Sometimes all I lose is the outside temperature reading. Everything will then return to normal and work fine. I took it to the dealer and he said they could not diagnosis the issue unless it is actually malfunctioning. I don't/cant spend the money for a random diagnosis search. I feel like my truck is undependable although none of these problems seem to effect the engine operation. All help, ideas are appreciated.
If it were me, I’d start with the simple test of rebooting the truck by disconnecting the battery. Should also check the battery voltage. When you hook the battery back up, make sure the connections are clean and tight. If that fixes the problem, great. If it doesn’t, at least you eliminated that as a potential cause.
alcsr
6.4L Power Stroke Diesel
Mar 4, 2018 06:18 AM
JoeFerg34
Dec 15, 2012 01:02 PM
