what got this started...pass rear leaking like Cody said. No bull there boys. This is the first head plug I can say I have had to do.
the front on the pass head starting...ironically the driver head plugs we're fine and block plugs we're no leaking..all being replaced with brass tho. Not doing this again.
Nice set of 3 bar explorer heads would look purrrdy on there too, and wake that little small block right up. & a set of 1.7 roller ped mount rockers
Just saying
and if you are pulling the timing cover to replace the gasket, might as well put a new water pump on too.
because you know damn well the pump will start leaking 3 days after you get it all back together.
Just saying
Did that to a bronco and it was still a turd. Pointless and wish I had the parts back for the mustang I'm about to get...cause I need another project
Timing cover is off. Chain is cherry. I planned on needing one but it's just not needed. I would if I had any doubt.
Cody just did a WP so just gaskets and reassemble.
Might as well throw on a new timing chain and gears as well as a new rear main seal. Heck, it sure is fun spending other peoples money!
ahh chain honestly is in great condition. Rear main...new ptfe type here. Supposedly that's the new thing for these? Either way yea it was seeping so new one it is!!
all freeze plugs in block and heads replaced with brass. New oil pan,timing cover,lower intake gaskets.
Once it's hanging the rear main can go in then back in it goes I hope.
