front end sag
Old Oct 1, 2003 | 10:59 AM
thinksnow's Avatar
thinksnow
front end sag
Hi all, Does anyone know a cost effective solution to the front end sag on the PSD's. I did a search but couldn't find an answer
Old Oct 1, 2003 | 11:03 AM
basstardo's Avatar
basstardo
An add-a-leaf setup for the front will help. You might also consider a spring hanger systems to raise the front up a bit. The front end of my truck was sagging considerably before I put my lift on, but I replaced all the springs with the lift so the problem was fixed. I used to bottom the front out quite a bit before the lift. It's irritating, but not much you can do other than either replace the entire springs with stronger springs (X springs from a dealer) or what I mentioned before.
Terry
Old Oct 1, 2003 | 02:31 PM
thinksnow's Avatar
thinksnow
I just spoke with a dealer about a set of X springs. They list for $300 plus for the pair. OUCH! thats a bit steep.
