Rough idol when in traffic
Old Apr 8, 2019 | 10:47 AM
ZombieF150's Avatar
ZombieF150
Did you ever pull the codes from the truck? You went from vacuum line to fuel regulator now to fuel pump. How did you come to this conclusion or are you just trying the shotgun approach?
Old Apr 10, 2019 | 06:55 AM
Newtooldschoolfords's Avatar
Newtooldschoolfords
Well this truck is going drive me mad
Ok bought the code reader but no codes check engine light is off. Got a fuel filter and replaced it.run better but still acting funny I drive semi trucks so I know when it's almost like it's flooding out at lower rpms. Not shotgun approach just want it to run better. No vacuum leaks,fpr is new,plugs,wires,cap and button are new,. Checked fuel lines no kinks or leaks. It's been getting me to work everyday
.so I will have to wait till check engine light comes on.then run the code reader.
Old Apr 10, 2019 | 07:03 AM
timbersteel's Avatar
timbersteel
When you said no codes, did you get a System Pass code of 11 or 111?
Old Apr 12, 2019 | 07:56 AM
Newtooldschoolfords
No cofrs
No system pass code didn't say anything
Old Apr 12, 2019 | 08:10 AM
timbersteel
So that tells me that either you have a PCM problem or the pins/connector need cleaned.
Verify that the DLC Connector contacts are clean, corrosion free and then try again.
If that fails to get any results, then the PCM is suspect.
Old Apr 12, 2019 | 08:36 AM
rla2005's Avatar
rla2005
X2 to the above response. Sometimes those pins on the data link get really corroded. Use some contact cleaner or a small nail file to clean them up then try running the KOEO tests and Stored Code display again.
AnnoyedEasy3
Bronco II
Mar 30, 2015 01:12 PM
Doucheatron
Jun 14, 2012 09:38 PM
uncleben77
Aug 5, 2011 07:09 PM
ahksamio
Dec 16, 2003 06:10 AM
RCsanjose
27
Dec 28, 2002 09:28 AM
