Sponsored by: Real Truck
Cruise Control
Old Oct 1, 2003 | 09:41 AM
DAVE JR.'s Avatar
DAVE JR.
Cruise Control
I have a 1996 f250 pwrstrk with about 159000 miles on it .On the way home from work the cruise wouldn't engageit worked on the way in to work 14 hrs before. I checked the fuse but have not had a chance to go futher . Any ideas on where to look first any common problems with system . This is my first powerstroke and I still have much to learn about . Any help or info would be greatly appreciated.
Dave Jr.
Old Oct 1, 2003 | 06:48 PM
Kraut's Avatar
Kraut
Wierd but true
I had a F150 many moons ago that started to kill the cruise control when I tried to use the left blinker (i.e. changing lanes).
Turned out it was a bad blinker bulb that opened a sneak cirquit that turned off the cruise control when the blinker was activated.
The moral?
Check all of your bulbs and fuses. I've had some wierd things show up by seemingly unrelated (minor) failures (bulbs, fuses, etc).
Old Oct 2, 2003 | 02:13 PM
Ruggs59's Avatar
Ruggs59
i have the same problem any suggestions
Old Oct 2, 2003 | 03:08 PM
NoMo's Avatar
NoMo
In addition to the bulbs & fuses that Kraut suggested, be sure to check your brake light switch (at the pedal) too.
