Clean Cylinder?
Old Mar 20, 2019 | 09:28 PM
Fleetwood271's Avatar
Fleetwood271
Clean Cylinder?
Pulled the sparks plugs and checked each cylinder. Good news is 7 of them had only a small amount of carbon build up. However #1, was almost perfectly clean. What would cause this? The engine also has a miss under power. Head gasket? Or....worse?
Old Mar 20, 2019 | 09:40 PM
ford390gashog's Avatar
ford390gashog
All the plugs should be light tan, your clean plug indicates lean misfiring and that's not good. If the piston looks shiny then suspect head gasket as the coolant will steam clean a cylinder.
Old Mar 20, 2019 | 09:43 PM
Fleetwood271
Yes, the piston appears to have been "steam cleaned" :-(
Old Mar 20, 2019 | 10:19 PM
ford390gashog
Also worth mentioning is these engines have been known to lose the wrist pin retainer and the pin will wear through the cylinder into the water jacket. Pretty much the block is a loss at that point. What cylinder is ultra clean? If its cylinder 1 or 5 then it may be possible the intake gasket is leaking and a final weird thing that happens is the intake rusts so much it pin holes and sprays water right into the intake runner.
Old Mar 27, 2019 | 01:27 PM
lee's Avatar
lee
Hi,
I would run a Compression check and see if that tells you anything.
Lee
Old Mar 27, 2019 | 02:17 PM
Fleetwood271
Originally Posted by lee
Hi,
Lee
Did that. Compression test shows good.
Going to check back pressure over the weekend.
pineconeford
19
Apr 19, 2016 07:33 AM
Vanzal15
22
Feb 10, 2016 05:13 PM
ford23
Apr 29, 2003 07:08 PM
oleblue70
Jan 16, 2000 08:46 PM
