Meanwhile Another Build Thread
#49
Received 4,135 Likes
on
#50
#51
on
#52
#53
on
#54
#55
on
#57
Getting ready to start wiring ole Rusty. Picked up a EZ 21 circuit harness, I know it’s overkill but never know when I might want POWER EVERYTHING!
Got the gauge cluster apart and cleaned. Went to Hobby Lobby (craft store) and got paint and a brush to redo the gauge needles.
Also attached a 12v to 6v reducer to use the original gauges. Red is 12v, Yellow is 6v. + & - Markings are how the gauges were originally wired for 6v positive ground. Checked the gauges with a 6v battery and all gauges seem to be good (not sure how to check Amp meter).
Now to figure out how to wire the Amp meter.
#58
Trying to find enough help to remove the Panel’s body.
Need to repair both cab frame mounts, install all new shackles in the back and probably install a 9”. I’ll also wire brush and POR 15 it as well.
it will also make it easier installing power brakes, new shorty fuel tank and running all the lines (fuel, brake and electrical.
I got some kinda dirty, Again, cleaning out the Panel bed and trying to remove the rub strips, front, rear and side edges. Those Phillips head screws are a pain when they break the cages nuts on the bottom loose. Sorry no pictures of the inside of the Panel. Got to tired and forgot.
Since I’m going Patina on this one (no bodyshop issues now), I Wire brushed the firewall in preparation for POR 15, primer and some satin black to match the inner fenders & radiator support. Will clean up the inside of the air deflectors and give them the same treatment. Installed the front bumper after the POR 15 cured on the front of the chassis. Also reinstalled the motor mount for the 351C as well.
#59
Still fighting the mounting bolts single handed. None will unbolt, although I’m not sure what you’re supposed to use in the bolts square drive holes. Guess I’m gonna have to use a hot wrench.
Also still removing the side straps that hold the plywood bed on the sides. Not sure if it’s rust, crud or a combination of the two but rust buster doesn’t phase it and most are twisting off.
I did manage to remove the two rear panels inside the bed. Look at the accumulation of dirt and mouse houses. I filled a 5 gallon bucket and then started vacuuming. Haven’t looked in the vacuum to see how full it is.
Passenger side
Drivers side
Passenger side
Drivers side
