1978 - 1996 Big Bronco
Another Alternator Problem??
Old Oct 1, 2003 | 05:17 AM
Wakeboarder141's Avatar
Wakeboarder141
Question Another Alternator Problem??
My alternator died and had to be replaced about 3 months ago. Now occasionaly while I am in drive and stopped the volt needle will sweep from the "L" in Normal down to about the "R" and then back again. It only does it while I am in gear and stopped. It is not a constant thing; it only happens once in a while. It also only sweeps about every 4-5 seconds while stopped and then returns to normal. Does it sound like the stupid thing is going out AGAIN?? Not sure if this is related but for the last week or so when I leave for work in the morning my belts have been squeeling pretty badly. Any help would be appreciated. Thanks.
Old Oct 1, 2003 | 05:45 AM
mustangman65_79's Avatar
mustangman65_79
ok, I should know this, but don't. Is it a internal voltage reg, or extrenal?
Old Oct 1, 2003 | 10:19 AM
Kemicalburns's Avatar
Kemicalburns
it could be the gauge to. might check your belt , could be worn also what is your idle at when your stopped at a light when it does this??
late
Old Oct 1, 2003 | 10:31 AM
Wakeboarder141
It's an internal regulator. I don't have a tach so I can't say exactly what my idle is when it does it.
Old Oct 3, 2003 | 07:56 AM
mustangman65_79
Now that I read it again, sounds like a short, for either the guage, or alt, but sounds like the guage.
Old Oct 7, 2003 | 09:00 AM
Wakeboarder141
What would be the easiest way to check for a short and what can I do to fix it?
Old Oct 29, 2003 | 06:35 AM
Wakeboarder141
I noticed the voltage meter also drops about half way sometimes when I am in drive sitting still and I crank the wheel to either side. Any ideas?
Old Oct 29, 2003 | 09:56 AM
greystreak92's Avatar
greystreak92
That sounds like you have rubbed a short somwhere in the harness with some moving part in the column.
Old Oct 29, 2003 | 10:11 AM
83 Black & Chrome's Avatar
83 Black & Chrome
Short & Squeel
Short ,yea, check your positive cable going down to the Starter.
Squeel, yea, Thats your alternator trying to charge up the weak battery. Just a good guess...
Old Oct 29, 2003 | 10:21 AM
subdude's Avatar
subdude
When you turn the wheel at a stop the Power Steering pump has to work a little harder which puts a load on the engine that drops the idle RPM a tad bit. I guess a short is possible, but it sounds to me like either 1 your idle speed isn't high enough to keep the alternator spinning at a charge speed, or 2 the parts store sold you a bad alternator. I suggest taking it to a parts store and have them test the charging system.
ollirrap
17
Jan 27, 2015 07:02 PM
dmags
6.7L Power Stroke Diesel
Sep 7, 2014 06:50 PM
boatnfish
2009 - 2014 F150
Oct 29, 2009 11:08 PM
Dutch123
Nov 16, 2004 12:49 AM
jop1212
Aerostar
Jun 30, 2002 04:06 PM
