1990 F350 E4OD transmission shift Issue!
#64
#65
#66
#67
since i caused you a problem before, i reluctantly say this. If you think a valve is hanging up. remove them one at a time. they should easly drop to their bottom seat, and when reversed should fall back out on their own. no pushing or pulling. look for scratches and wear marks on valves. i think you said you replaced the 3 small acc valves in the kit. The small spring in the modulator that was not there before, is just to give it a head start. it just floated from factory. Also i have a new, untouched acc valve body, RF-E9 I could sell you for what i have in it. This should work 89-94.
#68
on
Automatic Transmission Tip: Vacuum Testing Valve Bodies
Maybe this time just take the thing to a trans shop and let them check it out for a few bucks for ya? Just how bad is the shift anyway? Neck snapping BANGING into gear I take it? I'm assuming its pretty darn harsh since your so persistent about finding the problem.Good on you for not giving up!
#69
Exactly.Did you inspect the bore at all last time?
The shifts are decently bad. feels like someone hit your back bumper slightly. I know what its suppose to feel like so its really annoying having it shift like this.
#70
Thank you. Does it matter if I tried the test multiple times? replacing the protection diodes will still work?
I am only finding 1000v 1A versions will this work?
https://www.ebay.com/p/25pcs-MIC-1N4...2256897&chn=ps
I noticed the top most one is orange and smaller, the rest are black like the ones I got from ebay. Should I be replacing this orange one with the black one or leave it alone or what?
#72
Hello,
@restoman92
@FORDF250HDXLT
@ifrythings
So I took the pan off and dropped the accumulator and valve body. I took apart the accumulator again and noticed some gouging in the line pressure and 2nd bore. Pics are attached. Let me know if you guys think this could actually make a hard 1-2 shift.
Thank you - Shaun
@restoman92
@FORDF250HDXLT
@ifrythings
Thank you - Shaun
#73
#74
#75
Sorry that was on purpose, the only wear is right at the end where I focused the camera, you can see the shiny silver circles that were gouged out of the metal. The surrounding bore walls are smooth.
