Problem with rectrief for 1986 alt
Old Mar 13, 2019 | 10:46 AM
jarek_rugby's Avatar
jarek_rugby
Hello .
My name is Jarek, from Poland and i am owner of 1986 f-150 with 302 ci engine.
I have problem with my alternator (60 amp i hope) . I need to put new regulator and rectifier but i do not know witch one will fit. Regulator i found and hope it will work (FORD CG131907, ARE9003, F784) but rictifier i do not know - GY-1360 or GY-1351 . anyone will help?
Old Mar 13, 2019 | 01:31 PM
Franklin2's Avatar
Franklin2
I did a google search for "Ford 2G rectifier" and this is one of many that came up.
https://store.alternatorparts.com/partnofr192.aspx
Old Mar 13, 2019 | 01:41 PM
1986F150six's Avatar
1986F150six
Thanks to the numbers provided by Franklin2:
https://www.ebay.com/itm/Motorcraft-GY-1351-Alternator-Rectifier-Bridge-For-60-65-70-75-Amp-Motorcraft-2G/183524314517?epid=1123914041&hash=item2abae6cd95:g :GvUAAOSwqnVb42-p
Old Mar 13, 2019 | 02:27 PM
jarek_rugby
https://www.ebay.com/itm/Motorcraft-...UAAOSwqnVb42-p
Hi.
I saw it.
What about GY-1360??
Old Mar 13, 2019 | 02:58 PM
ford390gashog's Avatar
ford390gashog
Just buy a 3g alternator and get rid of the 2g alternator fire risk.
Old Mar 13, 2019 | 04:39 PM
Franklin2's Avatar
Franklin2
GY-1360 handles up to 80 amps. GY-1351 handles up to 65amps.
Old Mar 13, 2019 | 06:02 PM
JimsRebel's Avatar
JimsRebel
I would recommend starting with the Voltage Regulator (VR) first, it could be that the brushes are just worn. If you remove the 4 corner screws, you can remove it and check the brushes. There is a hole in which you insert a stiff wire, which will hold the brushes back for installation. You can change the brushes and reuse the VR.
Check to see if you have 3 wires on the VR plug. If you do end up changing out the VR you will need a new plug with all three wires, if you currently have only 2 wires like the one shown in the photo in post 1. The new VR will require all 3 inputs.
The Alternator Rectifier Bridge is very hard to change out as there are 3 heavy gauge copper wires that are soldered on the 3 attach posts. If you have to replace this it doesn't matter which copper wire goes where as all 3 of the inputs are all the same.
Good luck, Jim
78Hayride
Apr 7, 2019 09:43 PM
Gater180
26
Sep 9, 2014 04:07 PM
Dobies4life
Mar 10, 2014 10:39 PM
OsvaldoY
Nov 5, 2008 10:21 AM
ATC Crazy
Ford vs The Competition
37
Jan 21, 2008 04:33 PM
