I need help identifying how long my tail shaft should be
I'm not so worried about the speedo gear as my speedometer is 8 mph fast. I plan on going to a gps speedo before to long.
I'm just worried about getting a transmission that is too long or too short for my short wheel base truck. i dont want to have to do any thing with the drive shaft.
Why buy a used trans? It may be no better than what you have, could be worse.
You will be better off fixing what you have, rather then spending time searching for another.
So far, you've spent 5 days discussing this topic, it could have been R & R'd and fixed by now.
it is missing so thats all i have to go off of. i need to know what trans i need to order. there are 2 listed.
one that states
Automatic Transmission Assembly Rear Wheel Drive; Transmission Code: C6; 3 Speed; 7 Tooth Speedometer Gear; Tag ID: PGD-AW27, PGD-FF
and another that states
Automatic Transmission Assembly Rear Wheel Drive; Transmission Code: C6; 3 Speed; 8 Tooth Speedometer Gear; Tag ID: PGD-BD9, PGD-FE
from what i can tell the only difference is the spedo cable
one that states
I work in a parts store I also work another full time job totaling 80 hours a week.. I'm buying a remanufactured transmission because I dont have time or the knowledge on how to rebuild one. So that being said I need to know which of the two transmissions listed above I need to purchase.
I think @matthewq4b had offered to calculate for you the number of teeth in your current drive gear if you give him 1) your rear axle ratio, 2) diameter of your tires (in inches), and 3) the number of teeth on the driven gear (the one on the end of the speedometer cable).
See Post #13.
See Post #13.
#28
See Post #13.
See Post #13.
#29
As already said both transmissions will functionally be the same.
#30
That's my assumption but I'm worried one transmission will be longer than the other. I have to say you guys have been very unhelpful. All I need to know was if the transmissions listed above where infact ther same length. I have access to every thing but a drive shaft shop or aftermarket drive shafts to make this transmission work.im having to sell things to purchase a new trans as I dont have the money or the time to rebuild one or want to take a chance on a shop out here screwing up a rebuild.
