Upgrading 2001 7.3 Excursion
Old Mar 4, 2019 | 02:29 PM
molson09's Avatar
molson09
Gentleman,
I bought this Excursion almost a year ago and had to repair quite a bit of stuff once I bought it. I am new to the Diesel game and the time has come to finally do some fun upgrades for me...
Here is the list of items that I am hoping to get added to the Excursion very soon, can you guys give me some feed back as to what in your eyes is more important with one over the other and if I am just throwing dollars away. All of these items will be coming from Riffraff Diesel since they are local to me and I want to support local businesses.
MBRP 4" Aluminized Turbo back Exhaust or should I pony up and get the Stainless?
MBRP 4" in 5" out Black exhaust tip
Billet Compressor Wheel from Riffraff w/ turbo reinstall kit
PHP Hydra chip with 6 tunes from 1023
Complete CAC intercooler Boot Kit with new hose clamps
Bighead Wastegate actuator
Mag-Hytec Deep Trans Pan
Anything else I should be looking at instead? I do not want to get into injectors, I am scared to add too much power since I do not have forged rods/pistons
Old Mar 4, 2019 | 02:38 PM
pirate4x4_camo's Avatar
pirate4x4_camo
All reasonable additions with the exception of the transmission pan, other then looks it adds no performance or improvement to operations, all it does is look neat and cost more to fill with fluid.
An actual improvement to your transmission would be to add a cooler from the 6.0 And if you really want performance then a billet converter, red eagle clutches and tugger valve body.
Old Mar 4, 2019 | 02:47 PM
molson09's Avatar
molson09
I just had the transmission rebuilt 6,000 miles ago. It has a billet TC and built hell for stout ready for these additions and added HP. Also added a tranny cooler at that time as well.
Adding the transmission pan I was told that it would help keep the transmission cooler when I was towing my travel trailer, that was the only reason for that add.
Old Mar 4, 2019 | 02:53 PM
pirate4x4_camo
no it will not add any additional Cooling despite the marketing hype. The extra capacity will however take a tiny bit longer to get up to operating tempatures. With a billet converter and a 6.0 cooler you will have a hard time getting to the prescribed 170* operating temp as it is..... mine only runs 150* even towing unless it is a 100* day and then I am lucky to get it up to factory temp. Spend the $$$ Get a real trans temp gauge and skip the pan.
Old Mar 4, 2019 | 03:15 PM
molson09's Avatar
molson09
I have and Edge Insight CS2 for gauges also with egt probe. I saw above 200* in the transmission when pulling this summer, we have really hot summers usually above 100* and lots of elevation to deal with also.
Old Mar 4, 2019 | 03:36 PM
pirate4x4_camo
Oh I’ve seen well above 200 pulling 10 miles grades in Death Valley during the summer, but on the whole the 6.0 cooler handles the job.
the fluid handles up to 250* for realitively short periods, I consider 250* max and do whatever is needed to get temps dropping once it reaches that point.
Old Mar 5, 2019 | 10:06 AM
molson09's Avatar
molson09
The truck is mostly stock, I think it has around a 4" lift and 315 tires, should I look into re-gearing this thing instead of the other items I mentioned previously? I get horrible fuel mileage right now, around 10.5 mpg around town and maybe 13.5 mpg on the freeway. I was hoping getting all the other items would help with mileage as well as give me extra HP???
Old Mar 5, 2019 | 10:27 AM
M3rc's Avatar
M3rc
https://tiresize.com/gear-ratio-calculator/ to give you some perspective
Old Mar 5, 2019 | 10:44 AM
pirate4x4_camo
what size tires do you have ?
to determine yours lift measure from the center of the hub to the bottom of the fender arch, stock is 23” front and 24” rear
as for MPG, is that hand calculated or the overhead display ? Many tuners alter the calculations and give a false readout.
Old Mar 5, 2019 | 11:24 AM
molson09's Avatar
molson09
Tire size is 315/70R17
Driver Front- 26 1/2"
Driver Rear- 26 1/4" air bags have 20lbs in them though
Pass Front- 26 1/2"
Pass Rear- 27 1/2" air bags have 20lbs in them though
Hand calculated mpg. I use the Fuelly app
Old Mar 5, 2019 | 02:13 PM
bwguardian's Avatar
bwguardian
I agree about the trans pan...it will only get you more fluid capacity which somewhat helps, but the 6.0l trans cooler in conjunction with the pre radiator cooler will be best. Relative to the 4" aluminum or stainless...unless you're planning some future upgrades, the stock exhaust is fine as long as you get an open type muffler. However, I would definitely upgrade to stainless if you are somewhere up north where salt gets laid down on the roads during the winter.
Old Mar 5, 2019 | 09:09 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Skip the trans pan. Waste of money.
160/30 single shots will not be risky at all with PMR's. Forged rods do not even enter the equation until you reach the 500HP mark with our 7.3s. 1023 will be able to write tuning for the single shots (if you like their work).
With single shots, you will need a better turbo to clean up the extra fuel. 38R is excellent, or you can get the latest dynamo from KC turbos. Nothing but good things being posted about their product.
I bring up injectors and turbo because of the larger tires you are wearing. You can re-gear, or you can get some injectors and a turbo. Not much difference in cost between the two options, unless you are doing your own work...then the re-gear is easier on the pocket book.
Old Mar 5, 2019 | 10:01 PM
00t444e's Avatar
00t444e
Your not going to gain any mileage by putting lower gears in, it will most likely make it worse since you will be running at a higher rpm. 35" tires and 3.73 gears is just fine on a 7.3, I have been running like that for 4 years and have always had plenty of power even when I had stock injectors, I have never once wished I had lower gears. The Hydra, billet wheel, exhaust, and intake will really wake it up. Also I would just get the Hydra and try the tunes that come with it before you get the 1023 tunes, I liked the standard Hydra tunes when I had stock injectors, I have tried a few different tunes from 1023 with my current setup and I wasn't impressed.
Old Mar 5, 2019 | 10:03 PM
00t444e's Avatar
00t444e
Most importantly get boost, egt, and trans temp gauges before you tune it.
Old Mar 6, 2019 | 09:31 AM
molson09's Avatar
molson09
I am pretty sure that I have all of that through the Edge insight CS2 gauge, correct?
