7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Anyone want to take an early crack at what this beast is gonna be rated at?
Old 03-15-2019, 12:09 PM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is offline
Ford will likely have to put direct injection on the 7.3L eventually for emissions. It's true D.I. potentially produces more particulate emissions than port injection engines, but they are cleaner in other aspects and D.I. allows efficiency gains through higher compression ratios. It looks to me like the 7.3L already has provisions for D.I.. OIl dilution may not be an issue depending on the location of the high pressure fuel pump. The G.M. D.I. V-8's have no such issues, their high pressure fuel pumps are mounted externally. I think the 7.3L would likely have an external pump as well.
  #32
Old 03-29-2019, 09:15 PM
Butl85's Avatar
Butl85
Butl85 is offline
I'm going to guess 425/510. Large displacement with reduced power equals a long living engine. I know HP will be nowhere near 500 or torque near 600.
  #33
Old 03-31-2019, 09:34 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
I'm going to say 420 HP, 530 TQ. and very flat curves! It's certainly not going to set the world on fire in stock form, but will be a very viable option for people not wanting the high maintenance costs of the diesel. I'm more interested to see what hot riders can do with it in more-or-less stock form... I.E. ported heads and a cam.
  #34
Kevinm1980's Avatar
Kevinm1980
Kevinm1980 is offline
402hp and 465lb-ft of torque.. Because that's all they need out of it to be on top at this point
  #35
Old 04-01-2019, 07:04 AM
Sancho's Avatar
Sancho
Sancho is offline
It sounds like it won't have much more power than the 3 valve v-10. The 10 speed will help.
  #36
Old 04-06-2019, 01:33 PM
redbowtie's Avatar
redbowtie
redbowtie is offline
460/510, anything less will be a disappointment after chevy's 6.6 .. 401/465
  #37
Old 04-07-2019, 02:50 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
I'm surprised chevy didn't even top Ram's current 6.4 at 410 hp.
  #38
Old 04-08-2019, 07:20 PM
ncl's Avatar
ncl
ncl is offline
I dont think they need to because the torque is better. However it would help if it had more horsepower cause that thing is uuugggly.
  #39
Old 04-09-2019, 05:20 AM
someday's Avatar
someday
someday is offline
if its gonna be truely a "godzilla" i hope the numbers show it. regardless i think it will be well above chevy and fords 6.2 is practially there already. fords towing numbers are going to increase tremendously and the 7.3 numbers will need to back it up. also new hemis are around the corner too!!!
lastly, the new york auto show is coming up next week so that might be when some more info will get released
  #40
Old 04-09-2019, 08:08 PM
ShotgunZ71's Avatar
ShotgunZ71
ShotgunZ71 is offline
I’m not too terribly surprised, though. Yeah, it’d be nice on paper, but the old, archaic GM 6.0 consistently outperforms and outpulls in nearly every comparison test. It doesn’t have near the most power, but they get it to the wheels better than the others.
  #41
Old 04-09-2019, 10:17 PM
someday's Avatar
someday
someday is offline
theres also the chevy 8.x rumor
  #42
Old 05-10-2019, 02:02 PM
driximus's Avatar
driximus
driximus is offline
444 HP (444 cubic inches) 520 tq
  #43
Old 05-10-2019, 02:46 PM
Akley88's Avatar
Akley88
Akley88 is offline
that i thought was only gonna be in the medium duty trucks like the 4500 and up
  #44
Old 05-10-2019, 04:56 PM
Louisville Joe
Actually, it looks like the 4500/5500/6500 Silverados are getting a version of the new 6.6L gas V-8:
Silverado Medium Duty: Gasoline Engine Option Coming Soon | GM Authority
I think the 8+L will be for larger future trucks GM is doing with International.
  #45
Old 05-19-2019, 12:00 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
It'll likely be great between stoplights..........But towing, probably more like a "Gas-zilla"!!
Quick Reply: Anyone want to take an early crack at what this beast is gonna be rated at?
