Roof Rack Missing
Old Feb 27, 2019 | 06:56 PM
charles adams's Avatar
charles adams
Unhappy Roof Rack Missing
When I purchased my X I failed to realize that the entire set up for my stock roof rack was gone. No side rails and no cross rails. I did find the threaded inserts for the rack though. Question is, should I bother hunting down a stock setup or can I go aftermarket without much effort?
Old Feb 28, 2019 | 07:26 AM
unleashd's Avatar
unleashd
Go aftermarket or build custom like many have already done, if you are planning to use that storage space. The stock rack is completely useless, IMO.
Old Feb 28, 2019 | 07:35 AM
WE3ZS's Avatar
WE3ZS
While I would agree that the factory CROSSBARS are completely worthless (or at least nearly so) the roof side rails are fine. Like many here, I ditched my crossbars as soon as I got my EX home. I do use the side rails to mount my aftermarket towers and crossbars though, they work fine and carry the 3 kayaks perfectly.
In the OP's situation, I would look around the parts yards for a set of the factory side rails (and ends and hardware). But that's for how I use mine, depending on what the OP is planning to use his for may call for a full custom or aftermarket setup.
Old Feb 28, 2019 | 07:42 AM
unleashd's Avatar
unleashd
Tom, thanks for expanding on how to make good use of the crappy design of the stock roof rack. After a long thought, I recently ditched the cross bars. I really don't have any plans in the near future to load anything on the roof of the EX. But I am keeping the rails just 'cos I like that look better than the bald top
Old Feb 28, 2019 | 09:57 PM
charles adams
Hopefully I can find on X in a yard around here that has not rolled. I am not sure if I want to try and do the stock set-up and mod it or not. I was thinking about possibly going with a basket type but I am pretty sure that tey need the stock rails to mount too.
Old Feb 28, 2019 | 10:00 PM
charles adams
Or, I could just go this route...
Not my rig, just posting for the roof rack
Old Mar 1, 2019 | 06:24 AM
WE3ZS's Avatar
WE3ZS
With a basket type rack up there, like a simple aftermarket one, the factory side rails will most likely be your best bet to give it a good solid base. The earlier Expeditions may have the same or very similar side rails as the EX, but I'm not sure if the length is the same, I can measure mine later if you'd like to compare as there may be more Expys in the parts yards than EXs. With a big full custom rack like you pictured, you may be better off going with custom roof mounts with a bigger footprint to better distribute the rack and contents weight.
Old Mar 1, 2019 | 08:41 AM
Magnus E's Avatar
Magnus E
Twitchleprechaun is parting an Ex - check with him if he has the rails. https://www.ford-trucks.com/forums/1...ied-forum.html
Old Mar 1, 2019 | 11:36 AM
Excurvelle's Avatar
Excurvelle
Expedition rails will not work, not wide enough. I made my own using a combination of Expedition and Escape bars. https://www.ford-trucks.com/forums/1541833-finally-an-inexpensive-easy-roof-rack-build.html
Old Mar 1, 2019 | 12:06 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by Excurvelle
Expedition rails will not work, not wide enough. I made my own using a combination of Expedition and Escape bars. https://www.ford-trucks.com/forums/1...ack-build.html
I liked your modified crossbars back when you first posted that how-to, but I think the OP is talking about the roof rack side rails (the ones that are bolted to the EX's roof), not the crossbars.
Old Mar 1, 2019 | 12:26 PM
charles adams
Thanks for the heads up. I left a post. By any chance do you know what dimension hardware goes into the threaded mounts in the roof?
Old Mar 1, 2019 | 12:27 PM
Excurvelle's Avatar
Excurvelle
You are right. The roof bars should work, crossbars will not.
Old Mar 1, 2019 | 12:40 PM
charles adams
Should I be looking for any particular year set of Expy to snag them from or will they all pretty much be universal?
Old Mar 1, 2019 | 12:49 PM
Excurvelle's Avatar
Excurvelle
Personally I would look at an earlier model, the U Pull Its are full of them.
Old Mar 1, 2019 | 01:53 PM
1 Excursion camper's Avatar
1 Excursion camper
I still have my side rails but the cross bars are long gone. I accidentally broke one years ago taking it off. You can make your own crossbars.
