95 F350 engine conversion
Old Jun 13, 2001 | 05:50 PM
Franklin2's Avatar
Franklin2
Old Jun 13, 2001 | 10:54 PM
letti307's Avatar
letti307
[font size="1" color="#FF0000"]LAST EDITED ON 14-Jun-01 AT 00:01 AM (EST)[/font][p]Hello, I have a 95 F350 2wd with a 300 6 cyl., auto trans. It is a dual wheel with a 12ft stake bed and is underpowered for hauling purposes. I would like to convert it over to an 8 cyl. for more power. What vehicle should I look for as a donor vehicle, and what years? When I do the conversion, do I have to find one with a auto trans? Is it possible to convert to a standard trans?
Old Jun 13, 2001 | 11:22 PM
deere81's Avatar
deere81
You will need to find a F-250HD or F-350 with a 351 or 460 engine. You will also want an '87-'96 engine because they are fuel injected. You don't have to find an engine that had an auto tranny. Also you can convert to a manual but it takes some work because you have to add several parts.
Old Jun 14, 2001 | 01:14 AM
crazy_goodolboy's Avatar
crazy_goodolboy
How did you end up with a straight 6 in a dually ton truck? Anyway, swapping in a manual ain't too rough. You may have to make some custom cuts in your truck, and do a little jerry riggin, but you should be OK. You may have to change drive shafts. With some trannies, you'll have to find a 2-piece shaft (assuming you don't already have one.) Whatever you do, make sure you have the right flywheel/flexplate, otherwise you may inadvertantly ruin a good tranny. I'm surprised deere didn't mention that one.
Old Jun 16, 2001 | 10:20 AM
letti307's Avatar
letti307
Thank you fellas for you input. Now here is another question for you. If I was to put a 460 in that truck with my auto tranny would it bolt right up to my auto or would I need a different one?
Old Jun 16, 2001 | 09:29 PM
letti307's Avatar
letti307
What I mean is would it bolt up to my auto tranny or would I need another? I didn't word that right so I wanted to be sure you understood.
