Tire Size
Old Sep 30, 2003 | 11:57 AM
RIPPER's Avatar
RIPPER
Question Tire Size
I HAVE RECENTLY BOUGHT A '92 F-150 SUPERCAB LONGBED WITH A INLINE 6-CYLINDER. I WANT TO EVENTUALLY PUT A LIFT ON IT, BUT FOR THE TIME BEING AM GOING TO PUT SOME BIGGER TIRES ON IT. MY QUESTION: WHAT IS THE BIGGEST TIRE I CAN PUT ON THE STOCK RIM WITHOUT ANY MODIFICATIONS TO THE TRUCK ITSELF? CAN I FIT A 31"? IS THE STOCK RIM FOR THAT YEAR A 15" X 7"? WILL IT LOOK OK? ANY RESPONSE OR PICTURES OF ANYONE'S TRUCK WOULD BE GREATLY APPRECIATED. THANK YOU!
Old Sep 30, 2003 | 01:02 PM
muzz3256's Avatar
muzz3256
Is it 4x4 or 4x2?
Old Sep 30, 2003 | 01:32 PM
MustangGT221's Avatar
MustangGT221
The size of hte rim is usually stamped on the inside of the wheel. If it's a 7.5" wide wheel and 4wd truck, it'll be 32/11.5/15s. If you have a 2wd with 7" rims it'll be 31/10.5/15s.
Old Sep 30, 2003 | 02:31 PM
RIPPER's Avatar
RIPPER
4 X 2
Old Sep 30, 2003 | 03:09 PM
MustangGT221
2wd will be 31/10.5/15s.
Old Sep 30, 2003 | 04:27 PM
drewcoolness99's Avatar
drewcoolness99
does that go for '89's too?
Old Sep 30, 2003 | 06:52 PM
BurbankJoe's Avatar
BurbankJoe
I've been running 31-10.5s on my 93 2X F150 since new. They always looked small for the truck, but hold the ground well. find a set of "pull" wheels out there if you want a bigger footprint on a budget.
Old Oct 1, 2003 | 02:35 PM
MustangGT221
I had a stock 2wd F-150 at one point and 32/11.5/15s wont fit under the front without a lift. You can physically bolt them on, but theres no room for suspension travel.
Old Oct 1, 2003 | 04:14 PM
muzz3256's Avatar
muzz3256
I have a '96 2wd F-150 and I had to put 30x9.50 15 on mine, the 31's were too big and were rubbing insode on tight turns.
Old Oct 1, 2003 | 05:29 PM
weaponx's Avatar
weaponx
ive heard you can "shave" the wheel well to make room if the tire hits the sides.
Old Oct 1, 2003 | 05:41 PM
natewoz's Avatar
natewoz
Save the money and wait untill you lift it. Better to buy one set of tires than two- unless you need them right know. Just my opinion.
Old Oct 1, 2003 | 09:07 PM
ToyMaker49's Avatar
ToyMaker49
I'm A MANIGER AT A BIG 'O' TIRE STORE IN CAMERON PARK
YOUR VEH. CAN FIT A 31X10.50R15, THE BEST SIZE TO PUT ON YOUR VEH, IS A 32X11.50R15, IT LOOKS GOOD, BUT ON A SHARP TURN IT MAY RUB ON THE RADIUS ARM, OR SWAY BAR BRACKET, GO IN TO ANY TIRE STORE AND THEY WELL TEST FIT A TIRE FOR,
