Sponsored by: Auxito
Where to Mount CB
Old Sep 30, 2003 | 11:37 AM
smokeater1975's Avatar
smokeater1975
Where to Mount CB
Hello Everyone,
I have 2003 F150 Supercrew. I'm looking to install a CB and Antenna. Wondering if anyone had any good suggestions on mounting locations for these....
Thanks,
Smokeater1975
Lansing, IL
Old Sep 30, 2003 | 02:07 PM
wendall's Avatar
wendall
no idea on the location, just wanted to say hi to a fellow illinoisian. oak lawn are here.
Wendall
Old Sep 30, 2003 | 02:34 PM
JeremyH's Avatar
JeremyH
Mount the cb just to the right and below the steering column and the antenna just behind the cab at the top of the bed.
Old Sep 30, 2003 | 03:09 PM
smokeater1975
Well I'm a fireman so I have the switchs for the strobes just to the right and below the steering column. Good idea for the antenna though....
Thanks,
Smokeater1975
Lansing, IL
Old Sep 30, 2003 | 04:58 PM
JeremyH's Avatar
JeremyH
Then mount the CB just under the seat.....right between your legs......or hell....you could even mount it to the roof inside the cab.
Old Oct 2, 2003 | 10:21 PM
BigNateK's Avatar
BigNateK
i mounted mine under the radio facing up and put a "liitle wil" magnet mount antenna on the cab.. it works great
Old Oct 3, 2003 | 12:33 PM
peterbilt's Avatar
peterbilt
I have the Cobra with the electronics in the mic and a connector box. I think it's the 75W or something like that. Since I have a console I mounted the connector box in the bottom of the console with just the mic cable fed through a small hole. I am temporarily using a magnetic mount (large 5" base very strong) with a short antennae on the roof. But, I think I will make a permanent mount on top of my (under rail) tool box. Let us know what you wind up with.
Pete
Old Oct 3, 2003 | 01:02 PM
Doorgunner808's Avatar
Doorgunner808
I'm not sure how much experience you have with CB radios but this is my $0.02 . I mounted my twin firestiks to the corners of my bed near the cab. If your runnin a single antenae try to put it near the center of the truck (on the back of bed near the cab is ok) with at least 2/3's of it above the cab. As for the radio location, I would pick a spot where it is out the way yet ealily accessible at the same time. Close enough to mess with the dials without takeing all your concetration off the road. I mounted mine just right of the hood and park brake release handles. Also make sure you set the SWR after you have everything set up. You can get a cheap but good SWR meter from Radio Shack. They come with fairly easy to understand instructions too. I hope this helps.
DG808
Old Nov 6, 2003 | 08:02 PM
Frdbuy8589's Avatar
Frdbuy8589
I took a peice of flat steel bar that was 4 feet long and bout an inch wide. Cut 2 peices off the same length and drilled two holes in either side. Bolted the cb to the bars. Then I cut a 3rd peice the width of the cb. I then welded the three peices togather to form a u. Primed it and painted it gloss balck. Then I took 2 1 1/4 self tapping bolts and drilled through the bar into the floor. You need AT LEAST 1.25 inchers due to the ungodly amount of insualtion. I have the 60/40 bench seat so I put the base of the cb right about against the balck peice on the center hump with the floor ducts for the heater in it. I pushed all the extra wire under that balck peice to make it look neat. The cb's angle is right up at the seat so I can see it out of the croner of my eye.
The best part is you can make a longer peice of steel for either side and mount other stuff like switchs for your fire lights and a scanner. Got my idea from galls just cheaper and smaller. Good luck!
