Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2013 Escape coolant consumption
Old Feb 22, 2019 | 11:28 AM
daiges's Avatar
daiges
I have a 2013 Escape with the 1.6lt engine that consumes coolant. About every 4 months the low coolant warning light comes on and I add to fill it. The system has been pressure checked with no leak found. Has anybody else had this happen?
Daiges
Old Feb 22, 2019 | 11:45 AM
scott91370's Avatar
scott91370
It's either being burned or put into your oil (head gasket or intake manifold gasket) or when it heats up the overflow bottle is spewing it onto the ground.
Just have to determine which it is.
Old Feb 22, 2019 | 10:26 PM
simonsi's Avatar
simonsi
Daiges
Losing that amount over that period probably means they didn't wait long enough on the pressure test. I just had to cold pressurise my daughter's Tribute with my airline and leave it overnight to find a similar loss - turned out to be one of the heater hose joints at the firewall.
If you leave it over 2 days and you don't have a puddle under the car then check the footwell carpets, if not there then it must be internal in the engine (cylinders or sump).
metal13x
1997 - 2003 F150
Feb 26, 2008 08:16 PM
Mr. Bob
Dec 19, 2006 07:44 PM
BLK94F150
1997 - 2003 F150
Mar 12, 2006 10:08 PM
BrianA
1997 - 2003 F150
17
Jan 6, 2005 07:04 PM
aerocolorado
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 17, 2003 12:31 PM
