Computer Chips & Tuners
Superchips V10 bug?
Old Sep 30, 2003 | 08:48 AM
thespoon's Avatar
thespoon
Superchips V10 bug?
I had a recurring, annoying bug pop up about two weeks ago:
The Door Ajar light would come on and stay on, then disappear for no reason. Checked all the dooors, relevant wiring, etc. Checked error codes, still nothing.
On a hunch, I returned my truck to stock programming using my Superchips programmer.
1 week later and still no new Door Ajar lightings/sightings.
Problem resolved? I contacted Superchips and they are stumped. Any clues?
Old Sep 30, 2003 | 05:32 PM
thespoon's Avatar
thespoon
Bump:
How about it Ken? I bought this unit from you.
Heard of any bugs in the early units?
Old Sep 30, 2003 | 09:01 PM
FTE Ken's Avatar
FTE Ken
No need to bump... I'm juggling a lot but I get around to all the posts here sooner or later.
I've never heard of this type of thing with any Microtuner, I'm not even sure how that could happen. Are you running the stock tune now, or did you switch back?
Old Sep 30, 2003 | 11:08 PM
thespoon's Avatar
thespoon
Yeah. I'm still running stock.
The engine actually seems to run better, although the trans is mushy in stock trim.
I was getting a bit of flutter/pinging with MT program. Maybe the SC unit gags on the low-oxygen air /high-ethanol-fuel combo here (6k ft.). It's worse in winter when they really boost the alcohol content.
Old Oct 1, 2003 | 03:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is a well known problem with the door switch that is used in these trucks, check with the model forum for more info. It is not a computer problem.
Old Oct 3, 2003 | 03:19 PM
Ducnut's Avatar
Ducnut
I agree with Torque1st that it's a door switch problem as I've experienced it. A little WD-40 shot into the latch mechanism cured it. The local dealer says they see it all the time.
Old Oct 3, 2003 | 03:42 PM
FTE Ken's Avatar
FTE Ken
I'm glad to know this little gem of information!
Old Oct 3, 2003 | 06:25 PM
thespoon's Avatar
thespoon
No WD, the problem resolved itself - go figure. Prgram is back in no errors so far.
