2020 Ford 6.7 engine changes
Old Mar 12, 2019 | 06:55 PM
kper05's Avatar
kper05
I'll assume (speculate) the CP 4.2 isn't going anywhere considering Ram Trucks are using it for the 2020 HO 6.7L at 29,000 psi. I think that covers the big three with the 4.2 now but I don't specifically know what GM is doing with the Duramax for 2020.
Old Mar 12, 2019 | 09:18 PM
UGA33's Avatar
UGA33
Its staying around and they are increasing pressure to over 30k. GM uses a Denso system.
Old Mar 13, 2019 | 01:08 AM
kper05's Avatar
kper05
Thanks for the correction. I didn't know the L5P changed to the Denso HP4 but I see that now.
Old Mar 13, 2019 | 07:56 AM
Thom12's Avatar
Thom12
Originally Posted by speakerfritz
from past experience, I can say I am comfortable with the 4th year production run of the gen II 6.7 so I bought a 2019 last week. The gen II 6.7 was introduced in 2015 with a ton of fixes for the gen 1 6.7 introduced in 2011 which already had a tone of fixes based on 6.0 and 6.4 lessons learned.
from past experience, I can say I would not be comfortable with a 1st year production run of any new major engine change. The first year 6.4 and 1st year 6.7 were disasters.
Can't tell that from my early release May 2010 built 6.7, Flawless engine! Now the rear end hop, that's a different story...
Old Mar 13, 2019 | 09:07 AM
Overkill2's Avatar
Overkill2
Good for you! How many miles and still stock? My 16 has the hop. I plan on starting a thread when I do some stuff if it helps. Keep on trucking, Thom.
Old Dec 10, 2019 | 09:58 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
6.7L Power Stroke® Diesel 3rd Generation Engine Build Features and Facts
  • Fuel
    • New, higher pressure (2,482 BAR, 36,000 PSI) fuel injection system (2019 was 2,068 bar, 30,000 psi)
    • This 20% increase in injection pressure increases fuel atomization for more complete burn
    • A more complete burn increases fuel economy, and reduces emissions
    • Updated high pressure fuel pump to produce increase in common rail pressure
    • New fuel rails and lines to support more pressure and flow than ever before
    • New piezo fuel injectors capable of injecting up to 8 times per single power stroke
    • New fuel spray pattern built into the injector tips
  • Pistons
    • New 1 piece forged steel pistons to withstand higher combustion pressures with less friction
    • Openings cut into steel piston skirts to reduce weight to match mass of aluminum piston of prior year
    • Smaller wrist pin used to support the piston
    • New low tension piston rings (lowest tension in the segment) to reduce friction against cylinder walls
    • Piston rings fitted in tighter (closer tolerance) ring lands on the new steel piston
    • New split stream piston cooling jets shoot oil simultaneously at the underside of the piston crown and the wrist pin
    • Highest concentration of heat found in the underside of the crown of the piston, but high friction at the pin
  • Rods
    • New connecting rods (longer, to make up for shorter pistons, and stronger, to withstand higher pressure)
    • New connecting rod bearings (still investigating if IROX polymer coated or if different nitrided coating used, such as Ion Plasma)
  • Turbo
    • New, smaller frame, Honeywell turbocharger with lower inertia, for faster response
    • New turbine wheel
    • New compressor wheel
    • New dual axis variable vane precision support mechanics to support tighter clearances without wear
    • Redesigned vane kit supports vanes on both sides of the plates, instead of just a guide slot on one side
    • Prior version (2019 and earlier, to 2015) vanes were pinned on only one side, with one axle
    • Double axle turbo vanes allowed to run closer to the housing, which improves efficiency and performance
    • The closer the vanes ride the wall of the housing, the less internal air leakage, and the more flow efficiency
    • New 100% electrically actuated, electrically driven variable vane geometry controller with 4 bar linkage
    • Prior year vane geometry controller was electro-hydraulic, where the hydraulic actuation is slow to respond in very cold weather
    • Fully electronic actuator is more responsive in cold weather, thereby increasing turbo response by reducing lag time
  • Engine core
    • New engine block, with structural enhancements
    • New cylinder head casting, revising cooling passages and enhancing strength.
    • New front cover
    • New low pressure oil system pump changed from gerator type to gear driven type, size increased
  • Intake
    • New intake manifold, now a two piece design
    • Material swaps... what used to be composite is now cast aluminum, and what used to be cast aluminum is now composite
    • Lower intake manifold (non pressurized) is composite plastic to insulate better and reduce weight, as it operates in a cooler environment
    • Upper intake manifold (pressurized) is now aluminum to provide heat protection since it rides over top of the turbo, in a much hotter immediate environment
  • Other changes
    • Crankcase ventilation filter and oil separator housing is now composite plastic (this housing was cast aluminum in prior year)
    • Service interval for crankcase filters changed (interval difference unspecified... still investigating)
    • New larger oil cooler / oil cooler the same (equally empowered sources at Ford reported conflicting information on the oil cooler)
  • What didn't change
    • EGR cooler cooler carries over unchanged (revisions were made in 2nd gen)
    • New turbo still maintains all of the exhaust braking functionality as previous turbo
    • Entire engine upgrade package was weight neutral... no change in weight, despite 25 more HP and 115 more ft lbs of TQ
    • Industry Diesel Oil Standard remains as the older CJ-4, not CK-4. Ford recommends using Ford's proprietary oil specification.
See more (powertrain only so far) information about the new 2020 Ford Super Duty here: https://www.ford-trucks.com/forums/1...different.html
Old Dec 10, 2019 | 04:29 PM
bobcat67's Avatar
bobcat67
Very informative list, however I find it difficult to believe they still spec CJ-4 as many companies don't even make this formulation anymore. I am not disagreeing, however I think it is relatively ignorant on Ford's part not to spec CK-4. Or make engines and parts that are able to handle all formulations of CK-4 oil. Rumor has it the 19+ Cummins in the Ram pickups doesn't spec just any old oil anymore either. Will have to search harder to find specs / facts on this.
Old Dec 10, 2019 | 07:08 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The oil caps on Ford's 2020 6.7L pre production presentation displays said "CJ-4".
Let me verify the API designation Ford published for production, and I will be certain to report back if there is any change.
Note that Ford strongly recommends using oil that meets a specific FORD specification, irrespective of API designation. There are new CK oils that meet Ford's specification.
Old Dec 10, 2019 | 08:52 PM
bobcat67's Avatar
bobcat67
I hear ya, and I hope they've wised up a little, but if they haven't they need to. Could just be a money grab, but I highly doubt the level of Phosphorus in an oil is really going to make that big of a difference in wear, hell even some of Ford's blends don't meet their spec if you send virgin samples in to have tested.
Old Dec 11, 2019 | 04:38 PM
speakerfritz's Avatar
speakerfritz
  • Fuel
  • Pistons
  • Rods
  • Turbo
    • New turbine wheel
  • Engine core
    • New front cover
  • Intake
  • Other changes
grrrrr...you had to post this....bought a 2019 in March . Had I known a gen 3 motor was coming out , I would have waited.
Old Dec 11, 2019 | 06:28 PM
David1986's Avatar
David1986
Nothing wrong with your 19? How do we know that the 2020 changes are proven?
i would Enjoy the 19 and wait a year or two for the changes too tested.
Old Dec 12, 2019 | 10:25 AM
cjssr's Avatar
cjssr
I agree with that statement. The 2020 will be a first production year run like the 2011 was. Hopefully without some of the same issues!
Old Dec 12, 2019 | 10:30 AM
  #28
Overkill2's Avatar
Overkill2
And just think how far the 17+, especially your 19, has come from the 11 to 16s. You just bought the truck. Drive and enjoy it for awhile. I still like my gens look compared to the 17+. But I'd love to have that stock power level though.
COO
Aug 22, 2018 09:34 PM
cdnfireman
6.2L V8
Aug 3, 2018 11:28 PM
TopThis8899
6.4L Power Stroke Diesel
45
Sep 1, 2007 06:18 PM
Tyler_02
Feb 8, 2006 09:14 PM
haroldservice
Feb 25, 2004 07:00 AM
