Stabilizer Bar
Old Feb 20, 2019 | 04:56 PM
mtntop1's Avatar
mtntop1
Question Stabilizer Bar
Does anyone know where I can get a new front stabilizer bar and mounting hardware for a 95 f150 TWD.Ford discontinued this part.
Old Feb 21, 2019 | 10:36 AM
rdayt's Avatar
rdayt
The best place is probably your local junk yard.
Randy
Old Feb 21, 2019 | 01:16 PM
TexasGuy001's Avatar
TexasGuy001
The Hellwig aftermarket kits are far too expensive for what it is, so I vote salvage or parts truck.
Old Feb 21, 2019 | 07:43 PM
LSCRX's Avatar
LSCRX
How do you get the end-link mount off the spring perch? I tried and failed at the junkyard, figured there had to be an easier way.
Old Feb 21, 2019 | 11:32 PM
TexasGuy001
Sometimes you get lucky and find a truck with the sway bar end link bracket on the spring perch. If it is the bracket under the spring perch you have to remove the nut that holds the I beam and radius arm together. It is torqued really tight and requires using penetrating lube and an extra long breaker bar.
bigsmokey97
Sep 28, 2010 06:17 PM
tom1979
13
May 9, 2007 08:32 PM
UncleBob75
Oct 13, 2003 12:21 PM
